Question about Vehicle Parts & Accessories
Primer bulb will not fill with gas
Hand held leaf blower. can't get primer bulb to work will not **** gas to start engine.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Does it have a small hole in it or split check gas lines also
Posted on Sep 09, 2014
Will not start changed carburetor still will not start on back pack leaf blower
Check for broken gas line IN the gas tank. They tend to break right at the Stone Filter. Does this Blower have a Primer Bulb? can you see gas filling it?
Jun 12, 2015 | Garden
Husqvarna problems
No, it is a return line to the tank from the primer. It sounds like the hoses are reversed. The fuel should flow from the tank via the main fuel line (with the filter)( sometimes the main line is smaller than the return line) to the carb, fills the carb then to the primer bulb, and from the primer bulb back to the tank. With just enough fuel in the tank to cover the fuel filter start pressing the primer bulb. Check for fuel coming out the short hose into the tank. If instead the bubbles come out the filter and the primer goes dry try reversing the lines at the carb and/or the primer bulb and try again until you get the proper flow pattern.
Aug 29, 2014 | Husqvarna 125bvx Hand Held Blower Vac
I can't get it to start. Don't think the gas is moving when I pump it to start it. When I push on the bulb, it doesn't appear to pick up fuel.
Is the primer bulb filling with fuel.? If not then you either have a hole in the primer bulb or a hole in the fuel line, you mat also have a blocked primer bulb base.
Aug 03, 2013 | Garden
The purge bulb will no longer pull up gas so the blower will not start
Strip and clean carb, may have a blockage in the primer inlet, Do not use airlines or poke things in holes as these can also contain delicate small valves. Worth checking fuel filter too.
Dec 19, 2012 | Husqvarna Hand Held Blower 125 B Grass...
I cant get it to start. The primer bulb wont refill with gas
The bulb pulls fuel from the carb into the bulb and back to the tank, if the bulb does not fill it is because there is a fuel blockage, either in the fuel filter in the tank, or the screen in the carb itself.
Jun 03, 2012 | Echo 135 mph 390 CFM Gas Blower PB-250C
How to change primer bulb on Husqvarna 125 b leaf blower
Remove air filter cover,remove air filter, remove two nuts holding the assembly,pull primer bulb assembly out,remove primer tube. Reinstall in reverse order. http://www.ebay.com/itm/530047721-POULAN-WEEDEATER-RED-SNAP-PRIMER-BULB-/190568099240?pt=LH_DefaultDomain_0&hash=item2c5ebe6da8#ht_1848wt_718
Aug 31, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
