Question about Sony BRAVIA Televison & Video
No signal stuck on channel 2 with black screen. Model KDL37M3000
    Genius:
  • Sony Master
  • 1,039 Answers
Are you connected to a cable or sat box, Are you connected thru antenna input on tv or a/v input. If connect to box thru antenna jack of tv do channel search to pick up ch 3 if box is set to that. If connected to outside antenna still do channel searsh but be sure tv is set to antenna. If connected via av or hdmi the cable or sat box is bad.
Posted on May 13, 2014
2 Suggested Answers
  • 55 Answers
SOURCE: black box in middle of screen on 2 channels 42LG70 plasma model T
It sounds like your tv is in text mode for the captions. Try going into the menu, and go into captions, and set it to off. That should solve the problem. If not, do U have a cable box? If U do, try the same approach with the cable box B4 concluding it's something wrong with the tv.
Posted on May 01, 2009
My Panasonic plasma tv is stuck on one channel. The remote has new batteries but only works for the volume. I tried changing channels on the set itself and now the screen is black
If the screen is still on but is black, try changing the channel on the set itself back to the channel it was originally on. If you can provide me with the model name of the TV (usually somewhere on the back of the TV), I might be able to find out how to re-set up your remote with it.
Dec 13, 2016 | Panasonic Televison & Video
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
Insignia NS-30HTV 30 screen is black on all inputs, and says digital channel signal strength is low, can i fix this?
you need to get a digital aerial first .then you can sort out any other problems from there
Oct 03, 2012 | Insignia NS-30HTV 30" TV
Kv-29fa210, black screen with no signal message,can hear channel
If you are running some kind of sky tv for your stations it is your scart lead fault re-fit /replace
if not some times an dvd player if attached can interfare with the signal geting through
failling all that re-set your tv and re-do serach for channels again But it dose not sound like a tv fault but a signal fault.
if none of these work get back to me on pbviewingsky@yahoo.ie- and I'll try find out more on this problem.P
Aug 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TELEVISION FREEZES ON A CHANNEL AND WILL NOT LET PREFORM ANY FUNCTIONS
a sticky key on the remote or on the set will do that, or no signal coming in, see if you can find an auto-tune or -scan in the menu and run that.
Dec 09, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
Screen blacks out on HD channels
Saying that the problem is with your TV doesn't make any sense since your TV is fed from the cable box.  Your TV doesn't know one channel from the next.  If it had a problem it would effect all channels.  You may not have enough signal to the INPUT of your cable box due to a problem on the pole or at your house or both.  Insufficient signal can cause some digital channels to not get decoded properly by the cable box.  The lower channels will show noise symptoms such as what you describe but they won't crap out altogether like the digital ones.  Have a cable tech come out and measure the signals.
Do you have splitters in line with the cable anywhere?  If there's any way to beef up the amount of signal getting to the cable box try it.
Oct 15, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Televison & Video Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
