Question about Konica Minolta BizHub C650 Copier
How do i reset transer belt life metar
Tranfer roller unit life is full how can i reset it ?
  • Konica Minolta Master
  • 6,161 Answers
Was it replaced??????
Posted on Jan 15, 2016
Lifefitness treadmill belt sticks even though wax bag is full
It may not be sticking, but instead slipping on the front roller. You can resolve this by simply tightening the running belt. This adjustment will be done by using the rear roller.
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Tip
95T Treadmill Belt and Deck Replacement
Video Demonstration of a Belt and Deck Replacement on a Life Fitness 95 T Treadmill
  • This video demonstrates the steps necessary when performing a belt and deck replacement on a LifeFitness 95T treadmill
  • Tools Necessary:
    • 9/16" Socket Wrench or 9/16" Hand Wrench
    • Long Flathead Screwdriver
    • Phillips Screwdriver
    • 4MM Allen Wrench or Allen Socket
    • 8MM Allen Wrench
    • Plastic Putty Knife
    • Shop Vac or Vacuum
  • Begin by turning off power at the treadmill and unplugging the unit from the wall
  • Remove the upright tube caps from the inside of the uprights
  • Remove the Phillips screw and tilt the cap in at the top
  • Remove the motor shroud by first taking out all four screws in the shroud
  • Then remove the screws at the top of the front panel and loosen the lower screws
    • This will leave enough play to remove the shroud as shown in the video
  • Now with the Phillips screwdriver, remove the finger guards at the end of the treadmill from each side of the rear roller
  • You will need to slightly twist the finger guards to get them out from under the belt
  • Using the 8MM Allen Wrench, loosen the bolts on each side of the rear roller by 10 full turns
    • At this point, you can completely remove the rear roller bolts while keeping count of the number of turns at each side of the roller
  • Do not include the 10 full turns from the previous step, only count the turns for this step and make note of the number of turns for future referenc
  • Carefully remove the rear roller from the treadmill and set it aside
  • At the motor compartment, use the long flathead screwdriver to lift the tensioner arm and remove the drive belt from the drive motor pulley
    • CAUTION Pinch Point
  • Using the 9/16" socket wrench or hand wrench, remove the bolt from the front roller mount
  • Carefully remove the front roller from the frame and set the roller aside
  • Use the 4mm Allen wrench or socket to remove the 4 deck bolts from the deck
  • Once the 4 deck bolts are removed, you can pull the deck and belt from the frame
  • Be careful to not let the deck drop too far down into the frame during removal
  • Damage to the anti-static tinsel can occur if deck drops too low into the frame (as seen in the video)
  • It is recommended to thoroughly clean the treadmill before completing your belt and deck replacement
    • While the belt, deck and rollers are out of the frame is a great time for cleaning
    • Dirt, debris or other contamination can cause noise, early damage or premature wear on new parts
  • Use a plastic putty knife to scrape away any debris build up from the front and rear rollers
  • Vacuum most of the painted surfaces then wipe clean with a Sportsmith equipment wipe
  • Once you've completed the cleaning of your treadmill, it should now be ready for reassembly
  • It is necessary to install a new deck surface with the new treadmill belt
  • Your unit may have an unused side of the deck that can be flipped into use or the deck may need replaced
  • Before installing the new deck surface, inspect the tinnerman clips
    • The tinnerman clips are what the deck bolts thread into
  • Simplify the installation process by placing the new treadmill belt over the new deck surface
    • Ensuring the belt is installed in the proper direction
      • If marked, use the arrows on the inside of the belt
  • Now place the belt and deck into the treadmill as a unit
  • Install the front two deck bolts (closest to the front roller) about half way
  • Then use a long tool to line up the deck holes by the rear roller while placing your weight onto the deck to allow the bolts to start
    • Install these bolts in about half way
  • Now tighten all four deck bolts
  • Carefully insert the front roller under the treadmill belt and into place
    • Making sure to install the drive belt over the pulley on the front roller
  • Install the pulley end of the roller into the frame and align the other end with its bolt hole
  • Install the bolt and using the 9/16" socket or hand wrench, tighten it
  • Again, use the long flathead screwdriver to lift the tensioner arm and reinstall the drive belt onto the drive motor pulley
    • Practice CAUTION as this is a Pinch Point
  • Install the rear roller under the belt and while pulling back on the roller install the roller bolts on each side
  • Remember to keep count of the number of turns on the rear roller bolts
    • Reinstall the roller bolts using the same number of turns you noted from earlier
  • The belt may still be too lose, but that is ok as it can be fixed in a moment
  • Plug the unit back into the wall outlet and turn the power on
  • Start the unit at a very slow speed and observe the tracking of the belt
    • If the belt is not turning with the front roller, make small equal turns of the rear roller bolts until the belt begins to move
  • If the belt moves quickly to either side of the frame, quickly press the STOP key to keep the belt from being damaged
  • If the belt is moving to the left side of the unit, you can tighten the bolt on the left side of the rear roller
  • If the belt moves to the right side, you can tighten the bolt on the right side of the rear roller
  • Once the belt is tracking straight, move on to the next step
  • Re-install the finger guards over the rear roller with the Phillips screwdriver
  • With the unit stopped, step onto the treadmill and straddle the running belt with a foot placed on each side of the frame
  • Start the unit at a walking speed and begin to walk on the belt
    • If the belt stops on your foot fall or with your weight, make small adjustments such as 1/4 turns on each side of the rear roller until the belt slippage or hesitation is no longer felt
  • Continue this adjustment until no slippage or hesitation is felt at running speed
  • Now reinstall the motor shroud and upright tube caps
  • Log the repair into the Maintenance record of the treadmill display electronics
    • Press STOP then hold the PAUSE key until the display comes on and reads SERVICE MENU
    • Use the UP or DOWN arrow to scroll to MAINTENANCE and press ENTER
    • Display now reads MAINTENANCE MENU
    • Use the UP or DOWN arrow, scroll to REPLACING BELT/DECK and press ENTER
    • Display will read REPAIR LOGGED and will then return to the SERVICE MENU
    • You can press STOP key to exit the SERVICE MENU
  • This completes the belt and deck replacement on the LifeFitness 95T treadmill
Life Fitness Treadmill Belt and Deck Replacement Video 95T
on Apr 28, 2014 | Life Fitness Exercise & Fitness
The tools reset the counters for the 'transfer belt unit' (TransferBelt_for2500W(E).exe), the 'fusing unit' (FuserUnit_for2500W(E).exe) and the '2nd transfer roller' (SecondTra
Refer the parts life counter reset.Every time you change the fuser ,imaging unit parts you need reset the counters.Touch the screen exe. nad reset.
Jan 24, 2013 | Konica Minolta magicolor 2500W
How do I check if I have marks on the drum of my Canon Laser Printer (LBP2900B)?
If you have marks on your drum there would be repetitive marks every 76mm.
Interval (mm; approx) Roller or component
55 Feed roller
46 Transer charging roller
38 Primary charging roller
76 Photosensitive drum
31 Developping cylinder
57 Fixing film unit
56 Pressure roller
Dec 24, 2010 | Canon LASER SHOT LBP-2900 Printer
I replaced transfer belt cleaner and 2nd bias tranfer roller. need to reset consumable counter. how can this be done.
if both parts have been replaced then the Eng that have been onsite have to reset those values. Their are possible but required technical knowledge as their done on a Special Diagnostics menu on the device.
Oct 04, 2010 | Xerox WorkCentre M-24 Color Copier
Not sure which part that may need to be replace
tranfer belt is a large mylar black belt.
transfer roller is a skinny gray foam roller
Mar 13, 2009 | HP Color LaserJet 4550n Printer
HP2600n ? soft grainy texture printing in background
inside the image tranfer belt unit,there have 4 rollers ,just clean both end of roller and also the contact metal spring clean that and bend it little bit make sure it contact perfect, should be take care your problem
Dec 08, 2008 | HP Color LaserJet 2600n Printer
What is tranfer belt reset sequence for xerox phaser 6110mfp
There is no reset on the panel.You need to replace fuse on unit. 80ma !!!
Nov 25, 2008 | Office Equipment & Supplies
Replace Transfer Roller
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Jun 10, 2008 | Xerox Phaser 6250 Laser Printer
Konica Minolta BizHub C650 Copier Logo
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
