Question about Roper Washing Machines
Runs without water
Bought a used machine. First load worked perfectly. 2nd filled only halfway but ran perfectly otherwise. 3rd didnt fill with water at all but ran a cycle as if it had. I replaced the water inlet valve thinking it was faulty but it still runs without water. Maybe the timer's bad?
    Problem Solver:
  • 13 Answers
Water level is sensed by pressure against a diaphragm switch. This switch is always mounted above water level, and is connected to the bottom of the outer bowl by a plastic tube, usually 3mm ID. Either the tube has become blocked or the connection point. Also the diaphragm switch could be faulty.
Posted on Apr 01, 2014
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
  • 57 Answers
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Posted on Feb 16, 2008
  • 185 Answers
SOURCE: simpson esprit washing machine
put a new pressure switch in it
Posted on Mar 26, 2008
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
Machine wont fill with water
Does it run through cycles without filing or does it do nothing? If nothing lilely the timer otherwise the water fill valve id defective
Oct 12, 2014 | Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Speed queen AWN552 completed one load without a problem but machine won't start for 2nd load.
Does it fill with water? When you try to start a load, does the timer run?
Nov 09, 2012 | Speed Queen AWN542 Washer
Fills with water, not agitating
They probably dropped it a good one and jarred the computer. The bump bump bump down the steps into the basement. Hmmm rain on electrical components , if they used it right away and didn't give it a chance to dry out, yeah that might cause shorting across the board. The mechanisms are electronic now and not mechanical like the good old days (My uncle worked for Kelvinator and had old pieces laying around). What about overloading it? Are they overloading it? They've lifted up the cover and peeked at it and saw that it's not agitating? Are they incompetent? So many variables.
Jul 09, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Duet Washer Leaking
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LG 2077 CW-has IE code issue as well as soap dispensing problems
IE is an inlet error indicating that the machine has not filled up to the correct water level within 10 minutes. Could be a bad inlet valve, low water pressure or a problem with the inlet hoses (do not use anti flood hoses with these machines, use only the included fill hoses).
It sounds like all of your problems lie with the water fill. If the dispenser compartments do not get water added to them then the soap, bleach, and/or softener will not dispense properly. Then it will still be present and may dispense on the next load instead.
It is also VERY important that you use an HE (high efficiency) detergent and the correct amount (2-3 tablespoons per load). Otherwise you could end up with oversudsing issues which can also keep the bleach from dispensing properly.
Also make sure to not use GEL bleach, GEL detergent or GEL softener as they are too heavy and will not dispense properly. If all of these recommendations do not help then there is a definite issue with the incoming water supply from the inlet valves (especially if the IE errors continue). In that case you will need a technician to check the inlet valves inside the machine.
Hope this helps, please rate my solution.
Jan 04, 2009 | LG WM-2077C Front Load Washer
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Indesit IDL40, 2nd & 3rd light flashing
It can also be that the pressure is too week. If you look a tthe manual it mentions this exact symptom. I know because i ve a similar issue. cheers
Dec 13, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing Machines Logo
42 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
