Question about Innova 3030 OBD II Car Reader
Just gets stuck on read
I have a 3030 and it worked once on my subi just did some engine work and now it's getting stuck on read and the connect indicator will flash of and on but it won't connect or read codes any help out there
How do I read trouble codes for 91 geo storm? Scanners are to new to read.
that is true.
but some cars running obd1 , can be scanned,. (i have one)
like all GM cars and even older, , some ford, , Honda's . Toyota;s
but this car is GEO, (underdog, but is really what. a Isusu.)
Isuzu's cars are mostly not raced or sold here now. so who's going to make scanner for such a rare car and engine and EFI?
there is no OBD1 standard, each company uses a unique design.
then,... so...
OBD2, in 1996 a USA invention is a standard and all tools work.
so....
what you have is the old blink codes. wink wink...
all OBD1 cars work like this (or very close)
you connect a jumper wire, and the CEL lamp flashes codes.
so is the CEL stuck on? running.
must come on key on, bad lamp or bad ECU.
you can check out Isuzu Impulse
Example storm post..OBD1991 (USA)
To put the ECM (Engine Control Module/Ignition Control Module/Engine Computer) into diagnostic mode, where it will flash codes at you using the "MIL" (Malfunction Indicator Light or "Check Engine" light), short pins 1 and 3 of the ALDL/OBD1 connector using a paperclip. When you then turn the key into the on position, the MIL should flash once, then pause a bit, then flash twice. That means code "12." If there are other codes, they will be flashed out as well. All codes are two digits.
end quote, on storm
but where is the connector DLC?
and which pin is 1 an 3
so. we google more, or look it up in alldata.com like most do.
or here
http://www.robietherobot.com/storm/stormFAQ.htm
that was the 1st google hit, using clear text human questions.
DLC jumper storm or Impulse.
or diagnostic jumper Impulse.
join a Geo storm or inpulse forum and ask for scan tools.
they will be custom tools. (or hacked, as i have done)
Sep 17, 2014 | 1991 Geo Storm
My samsung sew-3030 won't keep the current date
To update firmware you will need a Microsoft Windows based PC and download the latest firmware on this website:
http://www.samsungsecurity.com/product/product_view.asp?idx=6404.
SEW-3030_mr8911isp-nor+spi_For US.zip (2.23MB)
Once downloaded, unzip files to your desktop and do the following sequence:
1st -> RUN file Generic_V1.0.0.0.EXE (USB firmware update driver)
2nd -> connect your wireless video monitor to power adapter
3rd -> press and hold select (enter) button in the middle of the dial.
4th -> connect USB cable to your PC. (screen will blank white instead of black) this is firmware update mode
5th -> RUN firmware update utility mr8911isp.exe , wait to USB connection (status bar will turn green) and show message ASIC: 0301 Device Connected
6th -> Press Update button and wait...
7th -> Update done! disconnect your device and voila! no more date/time issues and another bonus bugs fixed noticed: lower alarm beep volume, menu text size increased for better reading, temperature sensor more reliable
I Hope it help everyone having problems with this baby monitor
Jan 03, 2012 | Samsung Wireless Security Monitoring...
Brand Aficio 3030 and mpc5000 cannot get into service mode once error 672 is displayed. the only way was to replace the main controller if there any other ways to settle this error 672
I think that the problem is with the HDD. Did you try to remove the HDD? Try to un-plug it and turn machine ON. If it works you just need to format and recover the HDD. Or replace it with a new one
Nov 15, 2011 | Ricoh Office Equipment & Supplies
How do I connect my HP 3030 to my Macbook with MAC OS-X system? I can get it printing but do not know how to scan. Help please, Thanks Don Jepson, donjepson@shaw.ca
read this http://fixunix.com/hewlett-packard/101166-secret-drivers-laserjet-3030-other-hp-lj-all-ones.html that solves the problem but you need mac os-x v10.3
Mar 16, 2011 | HP LaserJet 3030 All-In-One Printer
Began running rough at start up and would correct itself after a bit. Now runnung rough all the time. Check engine light has now come on, but doesn't stay on continuously.
If the check engine light goes on for any length of time, there probably are codes stored in the computer that can give you clues as to what is wrong with the electronic engine controls, or mechanical parts on the engine.
Reading Codes 1985–94 vehicles Codes are displayed by the MIL flashing ON and OFF. The time duration of the flash identifies the significance of the digit. Three flash durations are used:
  • A flash duration of 0.5 seconds indicates no malfunction (OK).
  • A flash duration of 1.3 seconds indicates that it is a 10's digit.
  • A flash duration of 0.2 seconds indicates that it is a 1's digit.
For example, if 3 flashes — 1.3 seconds long — are followed by 4 flashes — 0.2 seconds long — a Code 34 is indicated. These code sequences are separated by 1.8 seconds to avoid confusing tens and ones digits.
  • Read Memory Mode: used to pull codes which have been stored in memory. It is most effective in detecting poor contact of wiring harness connectors. To enter this mode, connect the read memory connector with the ignition ON.
  • D Mode: used to diagnose and test the entire injection system. To enter this mode connect the test mode connector with the ignition ON. On the Legacy and SVX, the ignition must be ON with the engine running.
  • F-Check Mode: used to measure the performance characteristics of the injection system components. When working in this mode, a Select Monitor or equivalent scan tool is required.
  • U Check Mode: operates during normal engine operation. It signals the driver using the MIL only when components necessary for start-up and drive are faulty. The read memory and test connectors must be disconnected with the ignition ON for this mode to be operational.
Clearing Codes 1985–94 vehicles With the ignition ON and the engine running, connect both the read memory terminal and the test mode terminal
Aug 05, 2010 | 1991 Subaru Legacy
'92 Town car airbag indicator flashes, cruise control not working
you need to have a diagnostic done in order to get an error code and take it from there..
Sep 05, 2009 | 1994 Lincoln Town Car
Scanner reserved for pc scan
Get the latest driver´s for windows vista or get rid of windows vista it´s not a good OS extremely slow and very messy a lot of problems a resources consumption.
Hope it helps
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
On the way to work this morning hazard lights randomly flashed about 4 times in the space of 5 ks,thought it might have something to do with an electrics fault or is this a subie warning of some type(1997...
ahh yeah turns out i'm a muppet ,i had turned the imoboliser/alarm on ,while i went into the servo for ciggys and a coffee ,i didn't disarm properly and drove to work ,thank goodness subies rev high ,if i had stalled,could have been a little imbrassing,trouble with early morning starts .
Talken to winger in the morning No engine warning lights are connected to the hazards(and you can stop laughing at me now!)
on a brighter not i have my car booked if for a service ,thanks anyway
Jun 18, 2009 | 1997 Subaru Impreza
Hp 3030 scanner
Go to HP and download proper software, and drivers there is some scanner software in there to make scanner work.
Aug 04, 2008 | HP LaserJet 3030 All-In-One Printer
Innova 3030 OBD II Car Reader Logo
70 people viewed this question
Top Innova Measuring Tools & Sensors Experts
ray gallant
Vuk B
Tom Chichester
Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
