Question about Boost Mobile Kyocera Hydro Smartphone
Type password to decrypt storage kyocera hydro
Tried to encrypt phone and now it says it needs a pass. I put the one I set up before I did the procedure and every other pass I could think that ive used on the phone in the past with no luck
2 Suggested Answers
jackbreezeus
SOURCE: How do I update my 4.0.4 Kyocera hydro?
if your provider doese not have an ota availeble then you will have to root, find a updated rom and install it that way.
Posted on Oct 12, 2014
Can anyone give me some ulock codes for my HTC WD7 please
There are two sets of codes on a phone and there are no magic codes to unlock either, so forget that.
1. a Consumer set pass code or pass pattern. This can only be got rid of by a Factory Reset, AKA a Hard Reset. Google make model hard reset. Usually, hold power button and volume up button.
2. a PUK Code. This code has been put on by the cellular company that own the phone using an encrypted key at firmware level. They do this if the phone is reported stolen, if you are not buying their minutes, in default of payment, trying to use another cellular provider, or you have tried to unlock the phone with 10 failed attempts. The 6 digit lock code can only come from them.
Dec 03, 2016 | HTC Cell Phones
Get a new passwordhow do i get a new pass word
You need to follow the lost password procedure.
Dec 09, 2014 | Cell Phones
How can i unlock my cell phone it says that it is encrypted and that i need some kind of pass phrase
He has added a password to the phone. If he doesn't remember the password you may have to reset the phone if that's possible. Some won't allow a reset without the password or pass phrase.
May 28, 2014 | HTC Cell Phones
Removing encryption key
To open a locked memory card, select Options > Unlock memory card. Enter the password.
If you cannot recall the password to unlock a locked
memory card, you may reformat the card, in which case
the card is unlocked and password removed.
Formatting a memory card destroys all data stored on
the card.
Encryption
Select Menu > Tools > Encryption.
Encrypt your device or memory card to prevent
outsiders from accessing your important information.
Encrypt device memory or memory card
To encrypt the device memory,
select phone memory.
To encrypt the memory card, select memory card from the following:
Encrypt without saving key
• memory card without saving the encryption key. If
you select this option, you cannot use the memory
card in other devices, and if you restore factory
settings, you cannot decrypt the memory card.
Encrypt and save key
• and save the key manually in the default folder. For
security, store the key to a safe place outside the
device. For example, you can send the key to your
computer. Enter a pass phrase for the key and a
name for the key file. The pass phrase should be long
and complex.
Encrypt with restored key - Encrypt the memory
• card with a key you have received. Select the key file,
and enter the pass phrase
Oct 19, 2013 | Nokia E63 Cell Phone
My iphone 4s has no signal bars
There are many questions you can ask when your phone isn't gettng any signal. Like if your phone ususally doesn't get signal or did your old phone get signal etc etc. If you have put a os that is not the manufacturers sometimes your cell phone company will not be able to help you. What i suggest is that you put the orignal os back on the phone and it ususally will work. If not then call your service provider b/c there actually might be a outage in your area.
Mar 01, 2013 | Apple iPhone Smartphone
Setup 64bit pass phrase on Belkin router. All wireless devices say,
Do your other devices support 64bit wep, and are you selecting that as your encryption type on each device. For example I know on my cellphone I have to specify the type of encryption that is used. You might also log into the router, just to double check the encryption type and the pass phrase (even if you are spelling it right).
Jan 31, 2012 | Belkin Computers & Internet
Need to secure my router
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code. I hope this advice helps you out.
Apr 19, 2011 | Linksys Wireless-G WRT54G Router
I believe my system is being hacked. How do I secure my router if I can't find my software.
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 126 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code after that. I hope this advice helps you out.
Jan 16, 2011 | Linksys Wireless-G WRT54G Router
How do i password protect my Router???
follow the steps below:
  1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
  2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
  3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
  4. Click Security under Wireless menu.
  5. Under Security, you can select 64 bit WEP (or 128 bit WEP) or WPA/WPA2-personal (PSK). Note: make sure that your wireless computers will be able to support WPA encryption since not all wireless cards/adapters will be able to. if you're not sure, WEP is the encryption to use
Configuring WEP Encryption:
  1. 1. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
  2. 2. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Configuring WPA-PSK Encryption:
  1. Select WPA2-PSK as your Authentication
  2. Select AES as the Encryption Technique.
  3. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    Note: The PSK (Pre-Shared Key) is case sensitive ("A" is different than "a")
  4. Click Apply changes to save the settings.
once you have enabled your wireless security, you need to reconnect your wireless computer to the wireless signal using your wireless password/network key.
hope this'll help you and just ask me if you'll have other concern
ciao!
Jul 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Boost Mobile Kyocera Hydro Smartphone Logo
355 people viewed this question
Top Boost Mobile Cell Phones Experts
Lawrence Oravetz
M.B. Nataraj
M.B. Nataraj
Are you a Boost Mobile Cell Phone Expert? Answer questions, earn points and help others
