Question about Dell OptiPlex Computers & Internet
Can I put a PCI-e usb 3.0 express card in a dell optilex in a dell optilex GX110, since it only has usb 1.1
I dont own one but dont want to spend $30.42 for something with windows 2000 and usb 1.1
    Problem Solver:
  • 18 Answers
Yes you can if you have window 7 install on it
Posted on Apr 01, 2014
chinmay_lp
  • 271 Answers
SOURCE: sound card driver for dell optilex gx100 pc install with xp.
Here is the link to download your driver.Select your operating system and download.
Dell Optiplex GX100
DON'T FORGET TO RATE !!!
Thanks
Posted on Mar 12, 2009
  • 148 Answers
SOURCE: I lost driver for dell optilex gx60
hi,
go to support.dell.com > product support> choose by service tag > put in the service tag
and here you can download the drivers meant for your system.
further Queries are welcome
Please do rate me if you find my solution helpfull
Posted on Mar 17, 2009
jose_v17
  • 227 Answers
SOURCE: Compatibility of PCI-EXpress card for Dell GX280 (Small Dextop)
So if this is a slimline pc you are kind of limited in upgrade options
space being the biggest , then being followed with cooling ability, the best advice I can give you if specs say 350 is needed i wouldn't chance having the card pull more of a load off of the PSU than what is rated for it. Hope this helps
Posted on Mar 24, 2009
HeXx13505
  • 65 Answers
SOURCE: PCI Express slot not working
go into the bios and change the video settings from onboard video to pcie video
Posted on Mar 27, 2009
SOURCE: I/O card parity interrupt at 20000:0228
I know this is a very old thread but hoping it will answer the question of any one else searching for a solution.
I have recently been upgrading four Dell GX620 machines with an ATI HD3450 dual video card. I came across the
same problem on two of the four machine - which was odd - I have searched google for an answer but non was found.
I compared hardware and BIOS of Dell equipment but there was no difference - so how could 2 work and 2 not?
Battling on I ended up pulling the power, removing the battery backup and jumpering the RTSCRST on the motherboard to wipe all BIOS configs. After re-applying power the BIOS was reset as date/time was not set. Since this, the fault has gone away.
So for whatever reason this occurs, it seems it can be overcome by resetting the BIOS. A BIOS upgrade did/does NOT fix the issue. Loading BIOS defaults did/does NOT fix the issue.
JB
Posted on Oct 15, 2009
INSTALL PCI EXPRESS USB CARD IN DESKTOP COMPUTER
just plug the card and insert the cd and install it...
May 30, 2008 | Televison & Video
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
What Wireless card to buy
A version that is Wireless N.
You can install a Wireless N adapter card in any available (Open)
white PCI slot, or use a Wireless N adapter that plugs into any available USB port.
1) Dell Support > Studio XPS 8100 Desktop PC > Service Manual,
http://support.dell.com/support/edocs/systems/studio8100/en/sm/index.htm
I would like you to click on - Technical Overview
Now on System Board Components
The number 23 points to the white PCI slot.
The numbers 24 and 26 point to a PCI-Express x1 slot.
You can buy a Wireless N adapter card to fit either a PCI slot, or a PCI-Express x1 slot.
{NOTE* Number 27 points to a PCI-Express x16 slot.
This = NO.
This expansion slot is used for a graphics card, ONLY }
Examples of a Wireless N adapter card for a PCI slot, and a PCI-Express x1 slot,
A) PCI: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
B) PCI-Express x1:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=788312&CatId=2702
C) USB:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5079829&CatId=2688
Why use anything but a USB Wireless N adapter?
I don't know. They allow me to toot the whistle, but not drive the train.
Information on PCI, and PCI-Express;
PCI:
http://en.wikipedia.org/wiki/PCI_local_bus
PCI-Express:
http://en.wikipedia.org/wiki/PCI_Express
Regards,
joecoolvette
Feb 11, 2012 | Dell Studio Xps 8100 Desktop Computer
What type of vga card do i need for a dell precision 470
To take Full advantage --You have High-Speed PCI X (express) slot-(if its not already being used for something else)--and dont forget that you will need to disable the integrated one first.
Jan 02, 2011 | Dell Precision 470 PC Desktop
Purchased D-Link PCI Express card for my Dell desktop Dimension E521 and can't figure out if my computer has a PCI Express slot?? please help???
every computer will have at least one pci slot its white in color i insert your card in to the slot and press it tightly and screw the pci card to cabin and insert the cd received with the pci card and install them
Dec 15, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Card, Graphic, 128, X800, SE need to up grade the new high end
if you dont want to have to upgrade your power supply. your pc only has a 350w in it.
i would suggest the Nvidia 8800 GT if you dont have a budget or the 8800 GS if you dont want to spend too much.
both run 512mb and are superb for gaming. make sure you get some extra cooling in your pc so as not to overheat, these cards put out quite a bit of extra heat.
both are compatible with the dimension 8400.
Feb 25, 2009 | Dell RADEON X800SE, (128 MB) PCI Express...
I have a dell dimemsion 8400 pci express i want to change my video card.
ya ,
i dont think this problem is due to your graphics card,
but you have decided to change it is better.
Dec 14, 2007 | ATI All-In-Wonder® 2006 Edition RADEON®...
Computers & Internet Logo
Alun Cox
