Mistral gz 1002b e3
How do i set timer for this heat pump? and sleep mode?
2 Suggested Answers
SOURCE: My remote control will not turn on. The timer
take your chellphone and open the camera,then take the control and push any button in front of the chellphone.if the remote is ok you see a light blinking.if you didnt see the light the eye of the small plate have the problem.
Posted on Dec 09, 2009
I have an GZ-1002B-E3. I dont know how to get heatinh. How do I do with the remote control?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 12, 2014 | Televison & Video
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Manual for mistral air conditioner model GZ-1002B-E3
http://www.service-aerconditionat.ro/Manual_Aer_conditionat_Galanz.pdf
Jun 29, 2013 | Heating & Cooling
My elderly father has an older model Heller Air Con - code is GZ-1002B-EY We are able to get the cold air flowing but it will not go to hot air - what could be the problem ???
This might be a couple things M's Jackie. 1 the reversing valve is stuck or bad,2 the swtch is broken , Is this a heat pump. Meaning you use it to both heat and cool the home? There is not gas connected to this unit?
Jul 14, 2011 | Heating & Cooling
I have just taken delivery of an air conditioning unit using a GZ-1002B-E3 IR remote control that does not work. How do I get a new remote control?
This is a new unit and you must make a complaint to the dealer immediately to replace your unit. Make sure that the battery is good , the position of the battery is correct and the remote is aimed at the unit.
If not ask for replacement, file a complaint as a new unit has a warranty.
Feb 17, 2011 | Kitchen Ranges
My remote control will not turn on. The timer function comes on but nothing happens. model GZ-1002B-E3 mistral MSS2.6
Dec 09, 2009 | Hitachi RAS-09UH Air Conditioner
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Jun 08, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
