Question about HP DesignJet Z2100 InkJet Photo Printer
Q6692B need key
I need a product key for my Microsoft office starter 2010
I see you need an Office 2010 Product Key.
You will need to call Microsoft for a product key that will be legal and registered
Aug 17, 2011 | Microsoft Office 2010
Tip
DIY Replacement Ignition KeySubject: DIY Replacement Ignition Key Title: What to...
Title: What to do if you need a replacement ignition key
Overview:
There are times where you may need a replacement key. This can be the cause of a lost key, a key going bad, upgrading from the non all-in-one key to the all-in-one key.
Please keep in mind that if all keys are lost, there is NO WAY to program a new key to you car and a replacement TWICE module will have to be found with a key, either new (costly) or used and be married to the car via the dealer.
Symptoms:
Need a key, key is giving intermittent "bad key" messages and will not start the car, etc.
Experience Level:
Easy
Tools Needed:
Probably none, or a small tool to take the door off of a key via the hole in the side for the all-in-one key.
Time Needed:
Not much.
Parts Needed:
Key Blank from Dealer about $40 This is cut to your car.
Key Top from Dealer about $40 This is the "key guts"
all-in-one guts from Dealer about $90
all-in-one guts from ebay about $30-$60
key door from dealer for all-in-one key about $15
Procedure:
There are a few cases that can be covered
Case 1: Non All-in-one key replaced by non All-In-One key.
Subcase A: Have a non all-in-one key that is going bad
Solution: The dealer will have a replacement top for the key. Get the top, replace the top of the key and have it reprogrammed for the car. Total cost about $40 + $30.
Subcase B: Replace with all-in-one key because they are neato and / or the other key is lost.
Solution: Order the "Key Blank" from dealer and obtain the guts for the all in one key from ebay or the dealer. Have keys programmed by dealer. Total cost about $35 + $30 + guts cost.
Case 2: All-in-one key replaced by All-In-One key.
Subcase A: Have key but is not working.
Solution: Get guts and have it programmed. Cost about $30 + guts cost.
Subcase B: Lost key, need a new key
Solution: Get Key Blank and guts and have it programmed. Cost about
Outcome:
Very nice. Replacing the non all-in-one with the all-in-one dramatically increased the range of the remote. over the banana style remote.
Notes:
- Replace the battery in the guts if you get them off of ebay.
- You have to have all keys and remotes to dealer for programming.
- The guts for the non all-in-one key do not have the remote guts
- The guts for the all-in-one key have the security and remote in one
- The key shaft from the ebay all-in-one key can be discarded
on Jan 17, 2010 | Saab 9 5 Cars & Trucks
How I take out my ignition switch without the key.
hi.
the ignition units on all modern cars are designed so they cannot be removed without the key.
you normally need to turn the ignition to position I or II before you can remove the ignition.
without the key, you would normally need to change the steering lock assembly.
also, the key in most new cars has a security chip inside the key itself to confirm the identity of the key itself, and if you replace the key, you would normally need to have the ignition module reprogrammed to accept any new keys.
without a key, you will almost certainly need to get a professional to sort this out.
Apr 11, 2011 | 1996 Ford Thunderbird LX
I need my smart movie 4.15 license key my device serial number is
Sorry sir but we don't supply any illegal keys in here. But you can try to buy your own genuine key online. Just visit there website. www.lonelycatgames.com
Mar 30, 2010 | Nokia 5800 XpressMusic Smartphone
Does not lock with key or remote
hi friend,
I presume you've changed the batteries? If the batteries are good I don't know what to tell you dude, might need a new one
shake the key while holding it close to your ear, if you hear something moving inside the key then you need new key. there is a chip in those keys that if it comes loose you need then a new key. unfortunately it's not very cheap, key cost a little over $150. just order the key from the dealer, and if they tell you they need to reprogram the key in the car tell them you just want the key, because the key reprograms itself. all you have to do is put it in and let it sit there for less then 1 hour, and it reprograms itself. some dealers will tell you they need to reprogram it so they can charge you an extra $100, but in reality you don't need the re programing, just let the key in for less then 1 hour, then it is ready. hope this helps u please rate me................. thank u for using fixya regards sivaranjini
Nov 24, 2009 | 2002 Mercedes-Benz S-Class
Need to program new ignition key
You should have received a key number plate with your keys when you got the car. You will need this key number in order to get a key replaced. If you need to replace a key, you have to use only Honda-approved key blanks (probably means you will have to get them from Honda). These keys contain electronic circuits that are activated by the
Immobilizer System. They will not work to start the engine if the circuits are damaged.
You should have received 2 master keys (black) and 1 valet key (grey) in addition to the Key Number Plate when you got the car.
I hope this helps you.
Oct 31, 2009 | 2000 Honda Accord
Microsoft Office 2007 - Product Key
The product key of your MS office 2007 is located on your CD case of MS office 2007 package.If you ahve installed it from other source then you will have to buy a product key.
Thanks
Feb 28, 2009 | Computers & Internet
Need licence key for smart movie
i need my personal licien key,...my serial no is 353360009927899
Mar 30, 2008 | Nokia N-Gage QD Console
HP DesignJet Z2100 InkJet Photo Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
