Flash drive not detected
Flash drive light not working
2007 chevy tahoe check engine light flashing blows black smoke
Black smoke - running rich
flashing check engine light - severe engine misfire .
A flashing " check engine " light means that an engine cylinder misfire has been. detected . You can drive it in for repair , just avoid any rapid acceleration or. deceleration because you can damage the catalytic converter. A flashing " check engine " light means that an engine cylinder misfire has been. detected
Jul 21, 2018 | Cars & Trucks
Hi, my Transcend 500GB Hard Drive was working fine until it suddenly could not be detected by my Mac. When it was plugged in, the blue lights flashed but the presence of the device never popped up on...
This could eitehr be a physical problem due to drive damage or possibly a problem with the spindle. Can you hear the drive spinning up when the blue lights flash?
Jul 10, 2011 | Transcend Computers & Internet
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
Pen drive not working
my 2gb transcend pen drive is not detecting or hidden
Jan 03, 2009 | Transcend (589307) Media
Can't detect my drive
It could need a power adapter if it cannot draw enough from your usb port. I would try another port on the back of your PC.
Aug 02, 2008 | SimpleTech STORAGE, SIMPLETECH 500GB PIN...
Flash card detecting but shows no disk on drive
The card should be reflected as removable media automatically upon insertion in the card reader. Have you tried to use it with another PC? If it doesn't work in another PC, as it doesn't here, it is a hardware problem. As support info is light on their site, their forum was the only real place I found information. According to forum post (at http://shop.transcendusa.com/forum/index.asp), you should be able to get it replaced through the warranty & satisfaction guarantee if it is faulty. Further, their tech support at http://www.transcendusa.com/Contact/CuTechsupport.asp?LangNo=0&Func1No=6&Func2No=84 should assist you in further testing as necessary, and could also issue an RMA for return/replacement.
One part of your post I don't really understand is the statement that it is "detecting but shows no disk on drive" - and as well "It may detecting on Laptop intermittently". If you need further assistance, it would help if you could clarify this on your next post. Thanks for letting me know what happens, and for rating at FixYa!
Apr 28, 2008 | Transcend (589307) Media
Imation Swivel Flash Drive Cant detect
is it several times that youve used your flash driver at your office? and which side of the usb port did you plug it? coz when it is your first time to use your flash drive at your office and your plugging it at the front side of the PC. well there might be something wrong with connection and may cause damage to the board of the flash drive. if it your using it several times, well try to check at your PC, then do the following specs:
my computer (right click and select manage)
and under manage window ( select disk management )
try to see if your flash drive registered (you can see the drives of your PC) and see if theres a volume (either raw/ or theres a partition on it).
if not, well the board of your flash drive might be damaged, mostly these were caused by the power of the system, fluctuation is one of them, then improper plugging of the flashdrive.
Mar 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Check it another computer. If drive is still powerless, then you most likely have a failed flash drive.
Mar 03, 2008 | Electronics - Others
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
