Question about Panasonic Toughbook 48 Notebook
How remove bios password for panansonic cft7
Clear pass bios panasonic cft7
Clear bios pass
Hello Seb, try removing the toshiba motherboard battery run the PC and it will ask for a new password (sort of) or try cmos jumper. If you can provide more info on the unit better. try google search for clearing bios password.
Jan 02, 2014 | Toshiba Computers & Internet
How do I change pass word in bios setting?
hi
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
May 25, 2010 | IBM Computers & Internet
Pc has locked itself and i do not have the defaault hp pass word to log in
bios password ? or windows password ?
if its the bios password just clear the cmos or remove the bios battrie for few mins and disconnect all power and turn the pc on it will start for a realy short second its just to clear all the power wait 10-15 mins put back in bios battrie or put cmos jumper back in defult poz and plug it back in and away u go
Jan 27, 2010 | HP Compaq Evo W6000 PC Desktop
Bios password for panasonic toughbook cf 71
just clear the bios, by removing the jumper and put in its place again
Sep 29, 2009 | Intel Motherboard
I Have a IBM THINKpad and forgot the bios pass
Dear user,
pl remove power cable from cpu and open cabinet remove cmos cell and give power and check it. your password is removed.
2nd way is pl set cmos clear jumper in clear mode after given power to cpu.
Regards,
Ravindra Shah
Aug 02, 2009 | IBM ThinkPad T30 Motherboard 91P7695 -...
Administator password
You need to locate bios/cmos battery in roder to remove and clear your bios memory, this will able you to clear all present passwords
Thanksf
Apr 27, 2009 | Dell Latitude C510 Notebook
I just bought a Dell C510 cannot get pass the administrator, password to reformate my laptop
Thanks
Where is Cmos Clear jumper on motherboard to clear Bios password.
If you can't find the jumper, just remove the CMOS battery wait for 1/2 + hour and the re-insert the battery. This will reset the BIOS back to the default settings and you then need to set the Time & Date.
It may not remove the BIOS password if the laptop stores the password on an EEPROM chip.
Apr 16, 2009 | Acer Computers & Internet
Panasonic cf-w5 with bios password,i need to bypass the password.
Unplug from wall. Open computer disconnect battery. Plug battery back in . Plug computer back in and restart.
Dec 15, 2008 | Panasonic Computers & Internet
Panasonic c-29 toughbook BIOS Password breaking
you have to remove or unplug the cmos battery which is attached to the motherboard inside the laptop, doing this will clear all passwords. If the password clears replace the battery.
Here is some more usefull info if you want to this yourself>
The guts of the machine are usually under the keyboard. If you are okaywith opening up the laptop, you'll need to remove a few screws, thebattery and the hard drive, then carefully pry up the keyboard to gainaccess to the items that the manufacturers say you shouldn't tamperwith. If its just a matter of getting into the bios and theres apassword, you can usually simply remove the battery and leave itwithout power for at least 24hours, then it should reset....doesn'talways work but since most laptops actually do not have a standard cmosbattery, this would be one way to go about it. Of course you could justtry to figure out what the password is, someone has to have put it inthere so they should know what it is, or you could go to http://tcc.toughbook.com/ and get the bios update, which will reset it completely.
Nov 10, 2008 | Panasonic Toughbook 48 Notebook
Panasonic Toughbook 48 Notebook Logo
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
