Question about Belkin QODE Slim-Style Keyboard Case for Apple iPad Air
Meaning of keys on QODE Slim Style Keyboard Case for iPad Air
Explanation of labels on keys on keypad
Slim folio will not be found with new Ipad 6th generation, we followed the instruction and nothing happens
You have missed a step. Read again carefully
Connect the Slim Folio keyboard case to iPad
Before you connect your iPad 5th Gen to the Slim Folio keyboard case, make sure it's inserted correctly into the case:
Place your iPad so the camera lines up with the camera lens cutout on the Slim Folio case.
Snap the corners of the iPad into the holder to secure it.
To connect for the first time
The Slim Folio case doesn't have an On/Off switch. To turn on your keyboard case, open it and rest the iPad on the strip directly above the keyboard. The status indicator on the top right of the keyboard will glow green.
On first connection, your keyboard enters Bluetooth discovery mode and the status indicator will blink blue rapidly.
Go to the Bluetooth settings on your iPad and select Slim Folio in the Devices list.
If your iPad requests a PIN, enter it using the keyboard (not on your iPad).
Once the connection is made, the status indicator will turn solid blue. Your keyboard is ready to use.
To connect to a different iPad
If you've already connected the Slim Folio case to an iPad and want to connect it to another one:
Rest the iPad on the strip directly above the keyboard. This activates the keyboard. You should see the status indicator glow green, and then blue.
Press the Bluetooth connection button on the right side of the keyboard to make your keyboard discoverable.
Close
Apr 17, 2018 | Tablets & eReaders
Cannot get bluetooth keyboard to connect
Make sure the keyboard does not have a pairing relationship with another device in the room.
If there are any devices listed on the iPad, in Bluetooth settings, tap 'I' and forget Device.
Place the keyboard in pairing mode with a 5 second depress on power from the 'off' or no power state.
Type the keys on the keyboard that the iPad wants for the pair.
Aug 13, 2015 | Apple iPad Air
How do I capital letters on my apple air ipad key pad
In your Settings app, go to General-->Keyboard and make sure the "Enable Caps Lock" is on (green).
After Caps Lock is enabled, quickly touching the Caps key twice will lock it.
(Directions are for iOS 8)
Feb 16, 2015 | Apple iPad Air
How do I get the iPad Air to connect with the Qode Ultimate Keyboard?
The instruction manual on their website has a step-by-step setup guide that shows you exactly what you have to do for your first setup. If that doesn't work, the best thing to do is to contact their customer support (might be a faulty unit) Setting up and connecting the Belkin QODE Ultimate Keyboard Case for the...
Jan 13, 2015 | Belkin QODE Ultimate Keyboard Case for...
My shark keyboard for iPad air does not pair for blue tooth operation
Perhaps you look on this link to see you did everything right, like charging the battery, switching on and pairing. Don't forget to switch on bluetooth on your iPad. SHARKK Apple iPad Air Wireless Bluetooth Keyboard Case
Sep 10, 2014 | Apple iPad Tablets & eReaders
I updated my ipad to ios7 and my Targus Bluetooth keyboard does not work anymore.
I have similar problems with my Targus keyboard connection to ipad w/ ios 7, but not yet found solution. In my situation, connect can only be made after a complete power down. Keyboard is on; Bluetooth is on; iPad says it has discovered and connected to the Targus Versavu Keyboard, but keypad does not respond.
Oct 10, 2013 | Targus BLUETOOTH KEYBOARD FOR IPAD
My targus versavu keyboard case for my Ipad 3 is charged but I can't type
Thank you!!! I held the home key and power button until the Apple logo appeared and now it connects to the key pad.
Mar 11, 2013 | Tablets & eReaders
How do i get my keypad back to normal on my ipad
You have put the keyboard into split mode. You can split the iPad's keyboard in two by either tapping and holding on the 'toggle keyboard' button on the lower-right, or simply pulling the keyboard apart at the middle.
You can put it back to normal by pinching the keyboard back together or by tapping the button on the lower right.
Hope that helps!
Oct 19, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Keyboard Case For My New iPad?
I think you should go with zagg keyboard case . The case is the best seller and award winning also there are many other extra benefits of this product. To read real reviews on ipad cases click here to visit .
May 30, 2012 | Apple iPad Tablets & eReaders
Belkin QODE Slim-Style Keyboard Case for Apple iPad Air Logo
Top Belkin Tablets & eReaders Experts
Are you a Belkin Tablet and eReader Expert? Answer questions, earn points and help others
