Question about Canon Office Equipment & Supplies
Printer hp c6015
Replace fixing unit message won't go out
    President:
  • Canon Master
  • 2,017 Answers
The temperature of the fuser fixing unit is not being read as correct. Printer will require service to repair. Likely replacement of heating unit.
Posted on Feb 19, 2015
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
How do you fix an "opc-at-end-of-life" message
This is not a message you would ever see on an HP printer. You will only get a "cartridge empty" error. In most cases you will need to replace the drum unit on the printer.
Sep 05, 2014 | HP LaserJet 4350dtn Printer
HP c309a printer - error message 0xc19a0036, have cleaned the heads and the turned it off and on again and still won't work. Flits between error message ending in "36" and "24". Any...
hello, well, if you followed hp self help on the cleaning printhead, if you have then i would replace printhead, amazon seems to have the best price for the printhead. around $40.
Oct 10, 2011 | HP Photosmart Premium C309A All-In-One...
Will 27 black and 28 tri-colour cartridge work on a D1560 hp deskjet
HP 21 black and HP 22 tricolor cartridges are the cartridges compatible with HP DESKJET D1560.HP 27 and 28 won't work with your printer because they won't get recognized by the machine.It will only give you an error message like incompatible cartridges.
Jul 21, 2011 | HP D1560 Deskjet Printer InkJet
I have an HP 3055 all in one printer. When it's turned on and the scanner bulb is warming up it makes a clicking noise (like something is stuck) and an error 5 message comes up and says to turn it...
You can try this procedure that I wrote for the 3380. It works the same. click here
If this does not resolve the problem it is likely that you would need to replace the scanner mechanism.
May 08, 2011 | HP LaserJet 3055 All-In-One Printer
"PrinterHeads" problem reported. So I replaced with brand new ones. Same Message. Call HP....the have me restart to make sure. Same Message. Then HP says it's junk...no fix. True?
Unfortunately it is true. What happens if you get that error on one printhead and your replace the printhead and get the same error message... its the firmware in the printer that is bad. At that point if the printer is still under warranty the unit would be replaced along with the printheads. If not then unfortunately you would be looking at getting a new printer
Apr 06, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
57.03 Error in LaserJet P3005
One of the fans are not working. Unfortunatly, HP printers are not the easiest printers to fix. I reccomend having a certified HP technician repair the broken fan. If the printer is still under warranty, contact HP. They will either send someone out to fix it or replace the unit.
Dec 20, 2008 | HP LaserJet P3005n Printer
K60xi won"t align cartridges
what are going to do is just fix thee color ink cartridge of your printer......
Jan 26, 2008 | HP OfficeJet k60xi InkJet Printer
Printer Fixing Error- Replace Fixing Unit
You need to replace the fixing unit. It costs $120 and replacing it is not a trivial job. You may be better off buying a new all-in-one (not necessarily an HP). I've had good luck (so far) with Brother.
Nov 09, 2006 | HP LaserJet 3150 All-In-One Printer
110 people viewed this question
old marine
old marine
