Question about BenQ Battery For Joybook Lite U101 Lc05 Laptop
White Screen after shut down,but the laptop is turned on,display can be seen on external monitor
The screen are totally white,but can be seen through external monitor
SOURCE: BENQ FP731s Monitor Problem white blank screen
BenQ brand new high-voltage wire circle
BenQ LCD Controls circle / BenQ LCD accessories more high success rate, and easy maintenance, fault lower again!
Name : LCD Controls circle
Model : specifications : 1J.26048.011
BenQ LCD accessories four small mouth lights of the high-pressure reverse pressure plate used for high temperature must Taiwan curbs are enameled wire system. With a small noise, power, brightness control in high-efficiency low-loss. Rapid cooling loop can be designed according to customer-specific products.
2 features the use of high-precision inverter line Rao, insulation and can be a long time. 3 to 1. Electricity use light line measurement of high-frequency currents. 2. Backlight voltage output of a sinusoidal waveform. 3. The backlight brightness and the same as the original high-pressure plate. 4. 1-2 4.1 filament output AC exchange through the export of Maintenance and Spec - CN5 link to the. 5 and storage temperature and Temperature temperature ranges : -5 -- 50 ℃ work humidity range : 10% -- 95% RH the backlight should be within the scope of the above, the following conditions can store 40,000 hours. Operating temperature : -10 -- 80 ℃ work Humidity : 20% -- 95 % RH
BenQ LCD maintenance information
1 : BenQ LCD can switch planes normal (no signal light yellow, green signal), Looking carefully at the screen whether there are changes, they generally do not carefully read the screen can not see a change, oh, look at carefully Matata. Change or switch to a normal plane, the main board intact, such a high-pressure situation on board is no work, no lights lit backlight.
2 : disassemble machines, starting with high-pressure plate (box 220V piece of the plate), a screwdriver button open, not lazy. Power board and put the Main Board are removed, this is a good Off Power Plate,
3 : Measurement C5707, FQU11P06 (Some of the machines are used FU9024), whether the damage (breakdown) If the damage (breakdown), he seemed to see the appearance .22/160V capacitance whether deformation, If deformation replace, if not capacitance deformation on regardless.
4 : damage to the replacement of the device, if the fear of electricity burned again, you can Controls circle together too, In order to save costs if you should not start for high-voltage wire circle -- testing, If the damage C5707 meeting on the need to replace the high-voltage wire coils (most of the damage to the C5707 is Controls 72.9% Circle aroused),
5 : measurement of high voltage power supply board whether short circuit, without short-circuiting I would be grateful if insurance (PF801) new ones (General C5707 damage, insurance will certainly damage), If you do not have insurance you connect with fine copper wire, this 3-A insurance. Please stop the PF801 power-measurement, measurement inaccurate.
Understand how maintenance of electronic maintenance steps friends
2 : disassemble machines, starting with high-pressure plate (box 220V piece of the plate), a screwdriver button open, not lazy. Power board and put the Main Board are removed, this is a good power to remove board.
3 : replacement C5707 4 (Q809, Q808, loops, Q815) four high-voltage wire coils (T001, T002, T003, T004). 2 FQU11P06 or FU9024 (Qingdao, Q805). PF801 Insurance (insurance for the three A).
Posted on Dec 27, 2007
Marrie
  • 563 Answers
SOURCE: It just shows a blank white screen when I turn it on
Hi beans88
This is unfortunately a faulty Mainboard that will either have to be repaired or replaced.
The Part Number of this board is : 55.J8601.001 and if you decide to rather replace than repair it , you could expect to pay in the region of $125 for this part.
Thanks for using Fixya and good luck.
Posted on May 20, 2008
  • 225 Answers
SOURCE: my aoc lcd monitor appear full white screen
Most probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display on the screen. A replacement of LCD panel might be the solution. regards
Posted on May 15, 2009
tbreeze47
  • 3083 Answers
SOURCE: Benq FP92W monitor. The screen has turned white,
This isn't an easy solution, my friend. Go to this website and read what so many others are saying about the same problem. When you ger to this webpage, go to the link for the white screen problem, it's the same one you're having. http://en.kioskea.net/forum/affich-51640-laptop-screen-goes-white
I wish I could give you a simple solution, but there isn't one, sorry. These days it's usually cheaper to replace than fix, unless you get lucky.
Posted on Mar 19, 2010
  • 3 Answers
SOURCE: BENQ Q7C4 monitor shuts down after 5 seconds of
BENQ Q7C4 monitor shuts down after 5 seconds of login screen display
Posted on Jul 08, 2010
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
My 1545 turns on then the screen slowly goes white but when i mess around with the screen pushing it moving it up and down will come back briefly says Graphics display stopped working
Please test using an external monitor first,this will exclude motherboard issues if the external display is normal.Nearly all screens turning white that I have observed is a screen fault requiring replacement.
Sep 03, 2014 | Dell Inspiron Computers & Internet
How would the pattern on the screen change if a pure blue screen were substituted for the white screen?
What can you do if the laptop LCD screen turned completely white? 1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard). Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop. In some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful. Always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 31, 2013 | Computers & Internet
My acer laptop show white sceern only?
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope it helps
Jan 23, 2013 | Computers & Internet
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Here is problem in my newly laptop Dell Inspiron 1564. When i start it it screen shows totally white . After again and again start it is start and after some time or during my working it is again...
Try to plug in an external display (take the one of your desktop PC if you have). If it works on an external as normal then the problem is physical and it has to do only with the screen (new screen or invertor, or screen cable). If the same problem happens on the external monitor, do not touch the screen part. the problem then must be either video card or motherboard. I suggest try to do this trick with the external monitor to find the problem for youself and then use your warranty and bring it to the shop to have it repaired.
Oct 15, 2010 | Computers & Internet
The display turn white >>>what can i do?
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
It’s possible that you have to use a different key combination on your laptop but you get the idea.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Jan 18, 2010 | Samsung NC10-14GW Notebook
Hello, i have acer aspire one notebooki and have all the time white screen, so i cant work
Hi..
Your problem are related with my laptop problem, but i totally fix it with my own. From my experience I can tell that this problem may be related to the following:
1-laptop-white-screen.jpg Here’s an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose you using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I'm assembled everything back together and connected the original LCD, it’s still white.
That's my laptop brand and model, and i am searching an image regarding about my problem. This problem are common to another brand.
Hope it may helpful for you!
Good luck
ICmanServer
Aug 02, 2009 | Acer Aspire One PC Notebook
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
BenQ Battery For Joybook Lite U101 Lc05 Laptop Logo
20 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
