Question about LG Refrigerators
Hi I have the lg gr-151ssf it has a strange tube hanging inside hanging hown from the back ice box dont know where its supposed to sit or be. in the drip tray of the ice box ?
  • 520 Answers
Its actually supposed to be resting on the bottom and top taped to the back wall of refrig. This is there to store water before use to pre-cool it for the water dispenser. They do fall from time to time.
Posted on Jun 15, 2009
What has caused my water inlet pipe feeding the ice making machine to freeze?
It seems there is some blockage in copper tubes ( capillary)
Need to flush internally and then refill refrigerant
Jul 20, 2016 | LG Refrigerators
Water connection for LG GR-L28AUSJ
down toward the bottom there might be a water inlet that has a plug in it right now to keep dirt out .that will be the inlet supply
Dec 08, 2017 | LG Refrigerators
The ice box on the ice dispenser appears to be clogged so ice cannot be dispensed on either setting (chunk or crushed). How does one remove the ice box front to look inside?
Hello there,
For you to be able to remove the ice maker from the refrigerator, you will have to get a screwdriver and a work glove, then you follow the steps below:
  1. Pull the LG refrigerator away from the wall and unplug the electrical cord.
  2. Shut off the water supply valve to the ice maker by twisting the knob clockwise. The valve is built into the metal or plastic tube that feeds water to the ice maker at the back of the appliance.
  3. Open the freezer door and remove the ice bucket below the ice maker. Set the bucket in the sink for the ice to melt.
  4. Lift the white plastic housing off the ice maker and set aside.
  5. Remove the screws that connect the ice maker assembly to the inside back of the freezer, using a screwdriver and work gloves to protect your hands.
  6. Push up on the ice maker from below to release the mechanism.
  7. Disconnect the wire plug that connects the ice maker to the back of the freezer and remove the entire assembly.
  8. When you are through with what ever you want to do with the ice maker.
  9. Reconnect the LG refrigerator power cord and slide the appliance back to its original position.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | LG Refrigerators
LG GR-349R bottom mount freezer gets heavy ice build up in 3-4 days under lower drawer in freezer. L side of fridge near where fridge and freezer doors meet is very warm to touch.
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
Jan 10, 2010 | LG Refrigerators
Drippy LG Fridge
should be tray under freezer
Aug 17, 2009 | Refrigerators
Replace Ice maker tubing LG Armoire refrig
Normally I would change the entire tube, but if you like you can take a sample of the tube to a full service hardware store (not a big box where they don't know anything) and get some tubing and / or some insta-push fittings. They are fast and work great.
Dec 11, 2008 | LG LFX25960ST Stainless Steel French Door...
Ie tube freeze
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Jun 24, 2008 | LG LRSC26940ST 36" Side-by-Side...
Lg gr-l247tss
Yes just right under it . make sure not blocking the sensor..
hope it helps
Mar 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
Refrigerators Logo
315 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
