Question about Samsung DV419AE Dryer
Can this samsung gas dryer convert in electric dryer too
I bought gas. Dryer samsung and I moved to apt that Solent have gas connection I wonder can if can be convert in electric dryer the manual says the gas and electric dryer.
    New Friend:
  • 37 Answers
While it is possible to convert your dryer from electric to gas or vice versa, you will find the cost to be excessive and not worth consideration. A gas dryer will have3 a gas burner and ignitor circuit system while the electric dryer will have a heating element and controls. This is NOT a practical conversion nor would it be cost effective. If you need a gas dryer for your new home, purchase a new dryer or save a few $$$ and check your local Craig's List for a good deal on a used gas dryer. Just beware that you don't buy someone elses problem. There are legitimate sales caused by moving or upgrading appliances that will allow you to find a great bargain. Drop any notion of converting your dryer!
Posted on Apr 15, 2014
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
SOURCE: samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Posted on Jul 01, 2009
isaiahpro
  • 35 Answers
SOURCE: Samsung Electric Dryer
This may be a problem with your moisture sensor or the control that read the sensor. If it is under warranty have Samsung fix it for free. Make sure the cycle settings are correct before tinkering. First make sure the electronics are not too dusty. You could blow them off or vacuum them. Dirt particles can conduct electricity and make it read wrong. Next check the electrical connection for the moisture sensor. See if its location is in the manual. If it doesn't work after some tinkering asked the service for the dryer about possibly replacing the sensor but first try hard to get it to work.
Posted on Sep 21, 2010
hunter19_46m
  • 7482 Answers
SOURCE: how do I know if
Remove the back panel where the wire is connected to the dryer...
Here is the hookup for 3 to 4 or 4 to 3 wire hookups
Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Posted on Dec 13, 2010
kdrake84
  • 262 Answers
SOURCE: Need to know how to remove the front panel from
The model number that was posted is not in the data base.
However the listing I'm proviiding nay help you. It is designated by where the lint screen is located.
Simply choose from the listing. If your dryer style is not on this list then please provide your complete madel number so I may serve you better.
Click on the link to find your model number link http://www.repairclinic.com/Appliance-Parts
Here is the process for taking your dryer apart mentioned above.
You will need to decide which video fits your machine appearance.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.
Thanks in Advance and Thank You for using Fixya!
Keith
Posted on Feb 24, 2011
Can i convert dryer to electric dryer GE gas dryer model # dhdsr46gg7ww Is natural gas, need electric where I'm moving
not worth the cost--cheaper to buy an electric unit
any problem converting it to lpg ( jet size and shroud position change) and using bottles where you are going
Jan 04, 2017 | Dryers
What if i bought the wrong dryer
Two options:
1) Return the dryer and replace it with the correct electric model.
2) Call the local gas company and have them run gas service to the new appliance.
Jan 25, 2016 | Samsung Dryers
Can my kenmore elite HE4 electric drier be converted to natural gas?
No unfortunately it can not de converted ,besides after you bought all the parts needed you could have bought a new gas dryer
Sep 12, 2010 | Kenmore Elite HE4 Electric Dryer
Can an electric dryer be converted to a gas dryer? My new lease house has only a gas connection. If the dryer cannot be converted is it cheaper to buy a new dryer or have an electrician add an electric...
no you can not convert :-( putting in a dryer receptical is probably your line of least resistance it is typicaly 30 amps at 240 vac. so it will require special wireing 10/3 nmd7 , 2 pole dedicated 30 amp breaker, and a special receptical not a problem unless the basment is finished dry walled ect,, and you are trying to put the dryer on the second floor (far away from breaker panel) that could get costly fast ..get a qoute. just a side note I highly recomend using a licensed eletrician depending on where you live making modifications to electrical or plumbing in a leased house can leave you liable long after you move out
Good Luck
Oct 08, 2009 | Dryers
Need to convert kenmore gas dryer to electric. Just purchased a gas dryer and am moving to all electric. Is there an adapter kit to convert the gas to electric?
to convert u need an element and the high voltage cable three prong or four depends on ur plug in and what year ur home is i havent seen or heard of anyone getting a professional kit tho sorry hope i was some help
Sep 15, 2009 | Kenmore 74112 Gas Dryer
I have Whirlpool front load dryer ) I just moved into a house that has a hook up for an electric dryer...can this dryer be converted to electric?
Hi, how are ya?
To answer your question,
i your dryer is a gas then no, you won't be able to convert it to electric because a gas dryer uses 120V whereas an electric uses 240V.
Sorry, good luck :)
Aug 04, 2009 | Dryers
Samsung gas dryer convert to propane
Mar 18, 2009 | Samsung DV448AGE Gas Dryer
Convert a gas dryer to electric
Too much money.
A new dryer will cost considerably less.
Mar 03, 2009 | Whirlpool Dryers
Can dryer be converted
ummm, hter is NO way to convert a gas dryer to electric, you can have a gas dryer converted from naturall gas to lp gas, but not to electric, two totally different machines.
Nov 23, 2008 | GE Profile DPSB620GCWW Gas Dryer
Converting gas dryer to electric
No. There is no conversion. They work very differently.
Dec 16, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Samsung DV419AE Dryer Logo
111 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
