Question about Sharp Aqous LC-26D5U Television
Just blue just one day i was hooking up my dvd player the screen was blue but i got sound and i can see the menues but other than that just blue
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Re: just blue - Sharp Aqous LC-26D5U Television Flat Panel Televisions
Check connections and cables.
Posted on Dec 03, 2008
0 characters
3 Points
Broksonic 19 inch CCVG 1935 - no sound, no picture, just a blue screen
Blue screen means either no signal (if unit has rear connections hook a DVD etc to one and go to that input and see if it works) Or the blue may mean set is in shutdown----5 months old and it should still have a warranty?
Apr 23, 2012 | Broksonic CCVG1935 19 in. LCD TV
I just hooked up my Flat TV to my Panasonic VHS-DVD recorder player and the screen only shows blurry Black and White when displaying or recording, The TV itself is fine.
Sounds as if you hooked up your player wrong. If you are using a composite hook up. You should have a yellow, red and white cable. Make sure it gets hooked into the same on the TV. If it is a component connection, then RED, Green and Blue. It sounds like you have your Yellow composite going through your Green component. If by chance your TV is a new Sony, then you might have to go into the user menu and turn component off and composite on.
Apr 05, 2011 | Flat Panel Televisions
Screen is white
this could work unplug everything hooked up to it and leave it for 2 days then hook up the dvd and switch on it should detect it via the scart lead..good luck
Sep 14, 2009 | Sansui HDLCD-2612 LCD TV
When turning on the tv ther is a blue screen
hook up a dvd player into input 1 and see if you have a picture.if not,replace the main digital pcb.
Aug 08, 2009 | Westinghouse Electric SK-26H540S 26 in....
Tv is stuck on blue screen
i would suggest cycling thru the inputs- av1 av2 rgb hdmi. blue screen is indicator of no input.
Apr 07, 2009 | Flat Panel Televisions
Screen is green when trying to play a DVD
I think DVD player is hooked with TV via component video input.
Check component video connections and make sure each color wire connect in same correspondence color in both units, TV and DVD Player.
Red to red, green to green and blue to blue.
Dec 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Nothig bu a blue screen shows when turned on
Blue screen of Death?
No, this is not windoze.
can you change channels?
a blue screen usually means that you don't have a signal.
Is it hooked up through dvd/vcr player?
Try a straight connection to cable or antenna.
If it remains, then it requires surgery.
Sep 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Flat Panel Televisions
No sound, red screen
Sounds like the problem is being caused by bad cables or bad device signal. What is it hooked up to ie; computer, DVD player, etc. Check the cables themselves, start by checking the tips, try to make sure that none of them are bent or tweaked. Let me know what you find, and then we'll go onto step two.
Jun 08, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Sharp Aqous LC-26D5U Television Logo
62 people viewed this question
Top Sharp Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a Sharp Flat Panel Television Expert? Answer questions, earn points and help others
