Question about Tranquility 4mm Lake Fork Creek Cedar Click Resilient Vinyl Flooring
How can I make my resilient vinyl plank flooring shine?
Floor is new but no shine at all
Flat floor slide on05 winnebago vectra Rt. Ft
Please restate your answer in the form of a question.
Nov 13, 2017 | RVs
Can plywood be glued to tile floor before laying vinyl planks ??
There are cement based compounds on the market that will allow you to just go over top of your tile floor. Make sure your tile floor is not loose anywhere, clean the floor well and use a patching compound over the existing tiles (this will fill in the grout lines and any uneven areas of the tile). It may take a couple of coats, maybe even 3 to get the floor smooth and level. You should be able to install your vinyl right on top of this and not have the added height of the plywood. If you insist on the plywood you could use a good quality construction adhesive with drilling and installing screws.
Mar 06, 2015 | Building Materials
Is it waterproof allure vinyl plank
Yes this plank is waterproof unlike laminate flooring
Dec 19, 2014 | Kitchen Ranges
Does my floor have to be level to put in tranquility click flooring over it?
Wood flooring manufactures state the floor must be level within 3/16" every 10 feet. That means if you have a straight edge at least 6 - 8 ft long and you lay the skinny edge on the floor and look for light under the edge that contacts the floor...or gaps, must not be greater than 3/16" if they are, a simple floor patch from Home Depot or Lowes that you trowel on will remedy those voids. You need to check for high spots as well by placing the straight edge on the floor and looking for a distinct rocking of the SE from the high side to the low side.
All this pertains to my experience with concrete slabs. If you have a wood subfloor let me know
May 02, 2014 | Tranquility 5mm Venetian Cream Click...
What product to use to clean flooring
Any vinyl flooring cleaner off the shelf at your local store will work.....
Get out there and take a look before you ask simple questions.
Apr 20, 2014 | Tranquility 4mm Pioneer Park Sycamore...
Freefit vinyl flooring coming up
Where it is coming up, the vinyl planks will need to be glued down with the recommended adhesive. You will need to contact the manufacturer of the planks to find out which adhesive the want you to use.
Nov 25, 2013 | FreeFit Plank Tigerwood Vinyl Flooring
Tranquility 4mm lake fork cedar click resilient vinyl flooring Planks are separating. Installer company owner says product is not strong enough to hold together when it expands and contracts with...
LL will blame the installer for sure but you realize , you bought liquidation Junk....
Bad product will have to be replaced / returned. (return preferred over replace any day)
Sometimes you have to send them a legal notice and follow up in small claims court. Thats where they will usually stand down and refund your money and ask for labor money too. They can't afford to take chances in court. I believe they have been investigated big time for falsifying labels and voc ratings on flooring.
Oct 27, 2013 | Tranquility 4mm Lake Fork Creek Cedar...
How do you get rid of white ***** residue from vinyl floors?
Vinyl is resilient. You can use a mixture of white vinegar and warm water to remove the stain.
Nov 20, 2017 | Building Materials
Tranquility 4mm Lake Fork Creek Cedar Click Resilient Vinyl Flooring Logo
57 people viewed this question
Top Tranquility Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Tranquility Building Material Expert? Answer questions, earn points and help others
