Question about Garden
Hrv filter reset
How to reset filter reset light on hrv
4 Suggested Answers
SOURCE: HONDA HRV,1.6/03. WHERE IS THE OIL FILTER
You cannot change the filter unless you have access to a lift or pit. It is located on the back of the engine, recessed above the front axle. I took mine to a friends garage and even with the car raised, it still took a filter wrench on an extension bar to get to it. It is impossible to reach it if all you have is a jack or ramps in the driveway.
Posted on Jul 11, 2010
jdvillanueva
  • 2098 Answers
SOURCE: fitted new filters in hrv
Hi cpttubwash,
We are glad that your problem has already been solved.
Listed information will help other people in the future with same problem as what you've encountered.
Have a nice day! Thanks for using Fixya.
Posted on May 02, 2011
SOURCE: just changed the filters on HRV but cant get the red reset light to go off have tried different things with the key pad but no luck
any body have an answer as to how to stop air filter change red light from flashing?
Posted on Oct 03, 2013
Honda hrv problems
I have a 1999 Honda HRV I have just replaced the SRS unit and now the RPM when in idle goes up and down causing fuel consumption problems how do I fix this problem have taken to mechanic he mentioned it was due to the gearbox????
Jan 13, 2014 | Cars & Trucks
How do I reset the "change filters" warning light on my HRV home ventilation control panel
Filter quality is normally detected by an air flow switch. It has two tubes, one on each side of the filter and works by a pressure differential. Trace the tubes to their switch and LIGHTLY blow and suck on either tube. If the circuit board and switch are OK, it should reset and the light should go out. If this does not work, you will probably need a service tech. to find and replace a defective part.
Sep 02, 2013 | Audio Players & Recorders
How do i turn off the warning light on my hrv control pad after i have changed the filters
If you positioned them properly, when you changed them. It will eventually turn off by itself. This happens a lot with all types of AC & Heating units and it's no big deal.
May 07, 2011 | Heating & Cooling
How can I stop the filter light flashing on my HRV unit?
clean the filter its means the filter is to much dirty.
Dec 24, 2010 | Heating & Cooling
How to reset hrv filter light
1: Press the clip_image001.jpg button to turn off the screen.
2: Press and hold the down arrow button until an 02 appears in the Roof Temp, when you see the 02 appear remove your finger.
3: Using the clip_image001.jpg button - short continuous pushes until you see 02 on the top (Roof Temp) and 5 underneath (House Temp) NB: The light should go off.
4: Press the clip_image002.jpg and this will save your changes.
Oct 25, 2010 | Air Purifiers
Oct 02, 2009 | Honda CR-V Cars & Trucks
Is EDF5 required to have intermitant running of Fantech HR 2005R?
The SHR2005R will turn on the furnace Blower if the furnace is not running to circulate the fresh air. The reason the furnace will not trun on the HRV is, the purpose of the HRV is continuous Ventilation in your home. It should not be turned off when your furnace is not running. That why Fantech has not design the HRV's to run that way. I hope this helps.
Jan 18, 2009 | Fantech EDF5 Intellitek 5MR Control for...
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
