Question about Lasko Dryers
Fan needs oiling
Fan motor quit spining but has power
Fan just stop spining
Check for power getting to the affected motor. If power is reaching motor but it does not spin you might also want to check it for excessive friction in bearings caused by dirt/wear . Motor might have also burnt out its windings if it was spinning too slow and excessive current heated and melted the windings.
Mar 20, 2015 | Refrigerators
I have a Goodman CPLE30-1A outside unit and the fan stop spinning. The fan stop spinning so I turn off the main power to the unit and I can spin the fan with the power turn off so I'm not sure if its...
Hello
There are a few things here that could be wrong.
1 Fan motor start capacitor is bad.Silver battery looking device on side of fan.Remove and replace with a new one.
2 Contactor for fan motor is pitted or burnt .If this is the case you will need a new contactor.
3 Fan motor is bad.Check top two before assuming this.
Check all fuses and circut breakers also.
Aug 29, 2011 | Goodman CKL42AR42 Air Conditioner
Dv55ip empire wall gas furnace, the fan is very loud, needs help what to do.
Buday, it sounds like the blower fan and motor needs cleaning and oiling. This should be done annually and you can do it yourself. This should quite things down a bit.
According to your Owners Manual, here's what you need to do.
Servicing and Oiling the Fan Motor:
The fan motor should be cleaned and oiled once each heating season.
To reach the motor, withdraw the metal shroud surrounding the fan
blade by removing the screws on each side. Oil holes are located
on the top at each end of the motor. Use a few drops of #10 motor
oil. To clean the motor, blow air through its ventilation openings
with a vacuum cleaner or low pressure air source (canned air with a
straw nozzle like you clean your computer with works well).
Apr 04, 2011 | Empire DV-55 Heater
I think my ac window unit's motor/fan needs oiling.
'Oil Ports' are a thing of the past. Mfc's quit putting them on motors several years ago - mainly - so they could sell more motors - don't you know.
However, sometimes you can still "oil the bearings."
A trick I've done (with some success) is to take an electric drill and drill a hole on the hub (if possible) and squirt oil down the hole (on top of the bearing) and see if it will free up the motor. It's worth a try and like I mentioned (above) it's worked for me before.
good luck!
Jun 20, 2010 | Whirlpool ACQ122XK Air Conditioner
Fan will not start. Has been making noise but now will not move unless I push the blades, but feels stiff. Can it be repaired or must it be replaced?
Depending on the age of the unit/Fan there may or may not be oil ports, at the end of the motor, (Little plastic pull out's) Would use mechanical oil 3n1 ect.
Also The capasitor usually goes bad over time, which can be purchased at a local Hvac supplier usually less then $20.
If the Motor will not turn freely, several turns with just hand spining then more then likely you need to replaice the motor. Let us know how it goes. Can follow up with additional simple test for you if you need.
Oct 24, 2009 | Heating & Cooling
Fan won't start unless I push the blade. Does it
You can oil it, if you are talking about a metal-to-metal connection. I have started using silicone spray for a lot of things. It doesn't tend to degrade plastic like oil will.
Best regards, W/D
Aug 17, 2009 | Lakewood HV 18-c Floor / Box Fan
The fan seem to have quit working and the unit got loud. i oiled the fan but it doenst turn on but the compressor comes on but overheats quickly.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Jul 31, 2009 | Dehumidifiers
Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Nov 13, 2008 | Oreck XL2200 Bagged Upright Vacuum
Noise
the condenser fan motor is the culprit of the problem. all u have to do is replace it with a new one it would cost about 60 dollars
Feb 26, 2008 | Samsung RS2630SH Side by Side Refrigerator
Dryers Logo
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
