Mower deck spindle replacement
first take the blade off the spindle, then take the belt off the top, now there should be a nut on the top of the spindle you will have to remove that nut once you get that one off the pully will come off the spindle, now you will have to remove the bolts holding the spindle housing to the deck, put the spindle housing in a vise, put the nut back on the top of the spindle so that if you mass the threads with the hammer you are going to hit it with them you can fix them with the nut by taking it off again... now you have the nut on the top of the spindle and its in the vise, now hit the spindle to knock the bearing out of the bottum once you push the bearing out, you can remove the spindle out the bottum, now flip the housing over and take a punch and push the other bearing out if you are going to replace the bearings when replacing the spindle, i would reconend it... if you need anything else just xomment and ill repost...
good luck
