Question about Acer Aspire 5315 Notebook
Erecovery acer 5315
Iv just restored my acer 5315 back to factory settings and a box keeps coming up saying "installing erecovery solutions please wait" but i keep waiting and nothing happens, iv tried manualy installing erecovery but still whenever i restart my laptop this box comes up and i have to use the task manager to end the process.
anyone know what to do???
    President:
  • 2,653 Answers
You can "try" to stop the process from starting by unchecking the appropriate box under boot menu.
go to RUN, type MSCONFIG, check the startup tab.
Hope this helps.
Posted on Jun 15, 2009
Hello how do i restore my acer aspire 5332 laptop to factory settings
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at
http://www.vtechsquad.com/acer-support/
Jun 09, 2011 | Computers & Internet
Hi my laptop wont go to windows , it just saying prepare boot to os . can anyone help please
Windows may not be starting due to a driver problem. In any case, see if you can get into the Windows Advanced Options Menu as follows...
1. have the ac adapter connected
2. power on the laptop and watch the screen
3. when the Acer logo is showing, press F8 repeatedly
4. Windows Advanced Options Menu should now start
5. once you are in the Menu, use the up and down arrow keys to select an option
You could try starting with ...
Last Known Good Configuration (your most recent settings that worked)
OR
Safe Mode
where you could do a System Restore to an earlier date when the system was working
If none of this works and you don't have any user data that needs to be saved, then do as follows.
All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
1. have the netbook connected to its AC adapter which is plugged into AC power line
2. power on the netbook and watch the screen as it starts up
3. when the acer logo is showing, hold down the Alt key and press F10 repeatedly
4. until screen indicates Acer eRecovery is starting
5. once eRecovery is loaded, follow the directions given on the screen
May 08, 2011 | Acer Aspire 5315 Notebook
Hi i have a trojan on my acer 5315 laptop how do i restore it to factory settings thanks
Welcome to Fixya. Here is the standard Acer Recovery Instructions
1. Power on the machine
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit
If this wont work you need to use the recovery cd of your system. Take note that if you do the reocvery process all files will be deleted and the system will go back to default or factory state.
Thanks for using Fixya.
Mar 03, 2011 | Acer Aspire 5315 Notebook
Acer aspire 5315 VERY slow and types over words.Freezes up.
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Feb 03, 2011 | Acer Aspire 5315 Notebook
Hi i have a proplem in my acer aspire 5315 .When i boot it .i saw in screen boot "file messing..." id not rememmber what kind file.
It appears that the Windows is corrupted on your computer, you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Feb 01, 2011 | Acer Aspire 5315 Notebook
How do i reset my computer to its default settings
Thanks and regards,
Jitha
Nov 30, 2010 | Acer Aspire 5315 Notebook
Factory reset my laptop
NOTE - you will lose all your data and any installed programs if you do a full factory reset. the process will restore your PC back to how your purchased it
This link will explain how to factory reset the PC using Supplied recovery CDs if you have them http://support.acer.com/acerpanam/desktop/0000/Acer/Veriton5100/Veriton5100faq19.shtml
This link will explain how to factory reset the PC using the ACER eRecovery if installed on your PC
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq67.shtml
If you do have the eRecovery hidden partition installed:- How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | Acer Aspire 5315 Notebook
Erecovery forgotten password
Their is no password for an e recovery i think u given password in bios setup please remove ur bios password and run recovery.
Feb 12, 2009 | Acer Aspire 5315-2153 Notebook
My laptop wont go to desktop on startup.
Here is what you need to do
2. At the white ACER BIOS screen, hold the “Alt” key and press the “F10” key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, you can cancel the process and now your laptop should boot normally or you can click “Restore to Factory Default Settings”
4. Click “OK” to continue .
6. Once eRecovery has run, press “OK” to reboot unit
Jan 19, 2009 | Acer Aspire 5315 Notebook
How do i restore my lasptop to the factory settings
To restore your acer to its factory installation status (formats C: and removes all data) press ALT and F10 repeatedly on first boot. This should take you to the acer restore program which is partioned onto the hard drive.
Alternatively use the acer e recovery program to create a set of boot disks which will allow the same operation.
Nov 25, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
573 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
