Question about Car Audio & Video
What kind of subs should i get?
I need a truck box with them and an amp that suites them
  • 365 Answers
Clarify your make/model/year of truck, how much your budget can stand and your expertise on these installs
Posted on Jun 15, 2009
I am wanting to put my subs in the bed of my truck, how can I do this without rain or any other type of weather messing them up ?
Hello. Putting more speekers are a hassle. You will need to put them inside the cabin. You will need to get truck speeker boxes and they have to be the right size for the subs. You will also need to get the right kind of amp for them and the right kind of wires you will need. Good Luck.
Jun 01, 2014 | Cars & Trucks
12 inch sub(JBL) in box with a 500 watt pioneer amp, sounds good with some types of base. would you cut a port hole in speaker box?
riverray1969 it would help if I knew the exact model number of that JBL sub you are referring to. With that info I can provide exact specs.
Basically, you need to build/modify an sub enclosure that is suited for the sub, the music you mainly play, and vehicle tuning. Generally, sealed enclosures will provide tighter bass response and get decently loud. Some would argue that it will give you greater sound quality. A ported enclosure will give you a louder more booming sound. That depends also on where the port is tuned (ex. 32 hz, 36 hz, etc ). You need to make sure that the enclosure meets the sub's airspace requirement as well. A customized well made enclosure is just as important as the sub you put in it.
Oct 16, 2012 | JBL P-1020D Car Subwoofer
I have two different sets of hook ups on my Power Aucoustik 10" Sub. Do I hook up both sides?
Depending on the PA FUBAR you have. The voice coil on those subs are DVC. Dual Voice Coil. You need to know a couple things. What kind of amp are you going to run on it. And what is the resistance (OHM) rating of each voice coil. MY two 12's are dual 4 ohm. Meaning that there are essentially 4 speakers to hook up. My amp currently is not 2 ohm stable in bridged. So what I did is run each speaker in parallel (red2red,black2black) then run to the box terminal. So now the dual 4 ohm voice coils are basically 2 ohm. I have 2 speakers. Now I hook the box up in series. To bring the now two 2 ohm speakers into one 4 ohm speaker. This is called series/parallel setup. My amp sees this box as 1 channel @ 4ohms. The downfall to this is the output of the amp is divided up into each speaker. So instead of sending all 1400 watts to one sub. I will send 700 to each sub. But here is a catch. even though each speaker is half the total wattage it will still be 3db louder. Meaning it will be as loud as 1 sub running 1400 watts. To conclude i need to know how many of those subs you are going to run on the amp.. And the model number of the amp so I can match up your wiring.
Jun 06, 2011 | Power Acoustik FUBAR-12W Car Subwoofer
Would a 10ZX750.1 amp be alright on a Single Solobaric L5 10" inch in a ported box???
yes, the 10ZX750.1 is capable of running two L5's at two ohms in either a ported or sealed box. Just be sure to wire it up to suit your needs correctly (if you need to know how i can help) and make sure that your box dimensions match what kicker specify. the L5 is actually one of the subs that kicker reccommend for that amp.
Hope I helped , and please dont forget to rate.
cheers
Jan 15, 2011 | Kicker Car Audio & Video
AW1508X are they really any good?
The subs are good overall depending what kind of amp you are using. I personally use a ported box for all audiobahn subs.
Apr 30, 2010 | AudioBahn AW1508X Car Subwoofer
Need subwoofers
IF U HAVE A REG CAB U CAN BUY A TRUCK BOX MOSTLY FITTING 2 10INCH SUBS, AND A AMP UNDER YOUR SEATS, OR IF U HAVE A LARGER CAB THEY MAKE CUSTOM FIT BOXES BUT THEY WILL COST U MORE, OR U CAN GET A BOX FOR 1 12INCH SUB FOR A TRUCK AND U CAN PUT IT ANYWHERE U WANT.
Jun 16, 2009 | Car Audio & Video
10 inch subs need help
It sounds like the wiring either to the amp or to the subs is put together wrong. This can be because you have them setup in stereo but have the sub on bridge mode or vica versa. This can also be from how you ran the audio input wither from speakers or rca..either wired wrong or the switch for the two options is wrong. Also make sure your gain is turned up. Sound also depends on what kind of box it is in. It HAS to be in a box.
Jan 28, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Popping
If you Wire the 13 w7 in parallel you get 0.75 ohms which this amp is incapable of handling, that's why your speaker is popping. Be carefull cause this setup could ruin both your amp and sub. You have to wire that sub in series so that the amp "sees" a 3 ohm load which it's best suited for.
May 28, 2008 | Jl Audio 13W7 Car Subwoofer
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
