Question about Makita Crafts & Hobbies
How to remove rollers on makita 2030
Replace rollers
2 Suggested Answers
  • 885 Answers
SOURCE: I need to remove the jakobs chuck from my makita 2030 hammer drill
Open the chuck fully and remove the set screw inside it. The screw has left handed threads and is most likely lock-tited in so get a firm grip on it and turn it clockwise to remove it. The chuck is right threaded but put on very tight. The best way to losen it is to lock the short leg of a 1/2-inch allen wrench firmly in the chuck so you can hit the long leg with a hammer. If the spindle below the chuck has flat spots for a wrench, lock the wrench in a vice and put the spindle in it so you can hit the allen wrench hard enough to break the chuck free. When you put a chuck back on use a drop of lock-tite on the spindle and screw threads and turn them on as tight as you can.
Posted on Nov 06, 2012
I am looking for an owners manual.
http://www.manualslib.com/manual/98366/Makita-2030n.html
Jun 16, 2015 | Makita Planer-Jointer M-2030
My printer is saying i should replace used toner container?
Dear User,
I am sharing with you the following objects to help you achieve your desired results,
1. Service manual of your printer to understand the problem
2. A link to step by step, with pictures to understand how it is done for a Samsung printer (will help you understand the process)
Link 1. : http://diagramasde.com/diagramas/otros/SF2025_SERVICIO.pdf
Link 2 : http://www.samsung.com/us/support/howtoguide/N0000190/12120/144599
Regards,
Sid
Nov 13, 2014 | Sharp SF-2030 - Lower Pressure Roller -...
How to install drive roller on my makita 9401 belt sander
DONT forget to order and replace also allways the sinter bearingbus on the machine because to protect you from a dissapointment because otherwise the belt will turns off and cant be (good) controlled again , replace the drive roller allways and clean the front roller axle if its only dirt on the front roller use a little sillicon grease film on the front behind can use a little bit more sillicon grease between the axle rings and new bearing bus. remove the dry grease in the driving gear space and renew the lubricant in it with a multipurpose grease .
Sep 04, 2014 | Makita 9404 4'' x 24'' Belt Sander
Makita 9910
I think you'll need to replace the roller.
Aug 06, 2014 | Makita 3 x 24" Belt Sander
2030 power planer table moves, changing cutting height.
put a lock nut on the thread
after adjusting the height
lock the thread with the lock nut
Dec 02, 2017 | Makita Planer-Jointer M-2030
I changed the toner of my brother HL 2030, but since then the paper keeps on misfeeding: each sheet is blocked at the entry of the DR2000-unit, manual feed is working properly ... but nothing seems to have...
there could be two things that my cause this problem: 1.The ***** up roller is durty and needs cleaning(remove the cassete and look at the botton of the printer and you will see a rubber roller.clean it with cotton). 2.remove the rum unit and put it bag with bigger force so it will get nicly in the wright path.
Oct 20, 2010 | Brother HL-2030 Laser Printer
Brother HL 2030 Paper not feeding at all
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Mar 21, 2010 | Brother HL-2030 Laser Printer
My Brother hl 2030 has a permanent paper led light flashing altho there is no paper jam and all covers are secure
Feb 09, 2010 | Brother HL-2030 Laser Printer
I have got a piece of paper stuck in the printeer. how do i open ii up to get it out printer is hl 2030
just unplug the power cord and open the cover and remove the toner and try to roll the roller mannually and pull the paper slowly.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Brother HL-2030 Laser Printer
Crafts & Hobbies Logo
75 people viewed this question
Top Makita Crafts & Hobbies Experts
Tony Crow
Pieter Vleeshouwers
Pieter Vleeshouwers
FastHarley
FastHarley
Are you a Makita Craft and Hobby Expert? Answer questions, earn points and help others
