Question about Xerox Phaser 8560MFP Laser Printer
We have an error code09,008.43:9381. I checked
We have an error code09,008.43:9381. I checked all sticks and they are loose.
  • 23 Answers
You have an ink stick fault.
enter diagnostics power off then power on.
When powering on press the back and help buttons (at the same time) before the XEROX logo get to the center.
when in diagnostics. scroll to the function menu, then scroll to the clear ISC Faults and follow directions on screen.
Posted on Jun 17, 2009
Stick shift is loose but not grabbing any gear
check that the linkage is connected at the stick and on the box
the stick end may be a plastic eye on a pin and it may have come off or broken off
Nov 16, 2015 | Nissan Pathfinder Cars & Trucks
Error code 80 and then 138 quantum edge w/c
Low voltage. Check the batteries and connections to the power module and joy stick. Make sure no loose connections are present.
If problem still persist, then maybe new batteries are needed.
Sep 16, 2013 | Quantum Edge 6 Wheelchair - Used Electric...
Sl1 year 2000 with PO442 error. car was smoke
GAS CAP LOOSE OR FAULTY.THE PURGE SOLENOID OR VENT SOLENOID HAS A SMALL LEAK STICKING.
Jul 15, 2010 | 2001 Saturn SL
Verbatim 8G USB memory storage stick not working
There could errors in the drive. You should either run a scandisk on it or format it altogether. Either should get it back up and running is it is a genuine device.
1. To check for errors/scandisk right click on the icon of the memory stick, select properties. Under the properties menu look for Error-checking and select check now. The check disk menu pops up. See that Automatically fix file system error box is checked. Then click on start.
2. If you decide to format the memory stick just right click on its icon and select format. But see that you move you vital files from it first else you will loose them.
Sep 04, 2009 | Verbatim VER95327 USB Hard Drive
My sony digital camera model dsc w 220 is not working properly. There is a problem when that one getting 95 photos it shows file error, memory stick duo formatting is error. please just to guide to rectify...
Sounds memory stick is bad, try another memory stick in camera.
Current memory stick got storage problem on some specific capacity and gives error on reaching that limit. Buy another memory stick and check.
Jul 09, 2009 | Sony Cameras
1993 Nissan Sentra SE-R stick shift is moving to loose.
check the transmission selector rod, it just happened to my car last week. i could do reverse when i found out it broke. one thing that might caused it is too much pressure applied on the stick shift.
Mar 15, 2009 | 1993 Nissan Sentra 4 Door
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
Error: 09,035.43:27650
You have a Cyan ( blue) ink stick stuck or a broken ink stick in the ink loader.
Check the cyan slot carefully, one of the sticks has not moved properly, The machine is not seeing the ink loader moving indicating a stuck cyan stick, Here is the info.
Ink stick count faults (error code 09,03x.4x) are declared when the printer melts 2.5 ink sticks without tripping the color's ink out flag. The ink out flag is used to physically count ink sticks passing thru the ink loader.
Verify that the ink sticks are Xerox 8500/8550 ink sticks. Manually verify that the ink stick are correctly loaded and are able to advance in the ink loader chute. Check for broken ink sticks which can fool the ink out (ink stick counting) sensor.
The ink stick count fault can only be cleared by powering up the printer in internal diagnostics mode. Then scroll and to the Functional menu item Clear ICS Fault.
Dec 19, 2007 | Xerox Phaser 8500/DN Printer
Sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Oct 22, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Xerox Phaser 8560MFP Laser Printer Logo
104 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
