Question about Parallax Power Supply 7345 Power Center Electronic Converter/Charger
Power back feeds into generator on my parallax 7300
Shoreline power back feeds into generator is hooked up wrong
7155 Parallax Power supply 12 volt side problems, all fuses and wiring in good working order.
http://d163axztg8am2h.cloudfront.net/static/doc/b5/84/8f1a1586e9cb74379e85d9136830.pdf
Dec 12, 2017 | Parallax Power Supply PARALLAX POWER 7155...
Model 2011 jay flight g2 when hooked to AC power has 120 volts on external TV connector. Can I get an electrical schematic for the 29RLS floor plan?
What you are saying is when you connect that motor home to a shoreline power connector, the outlets are reverse polarity. You can confirm that with something like this: http://www.acmehowto.com/electrical/outlettest.php
You can get this tester at any hardware or lumber place. What caused this? Somehow the polarity got reversed and it is most likely at the connection on the outside socket. It can also be the shoreline drop cord or the breaker box. In an electrical outlet, the small slot is HOT and it should be connected to a BLACK wire. In an appliance like a television the neutral wire (white) is connected to the ground or the chassis of the device, when the polarity is wrong the chassis becomes hot and you get the problem you describe.
Oct 07, 2016 | Computers & Internet
Why does the cooling fan run all the time ?
I suggest you call Parallax Power Supply
100 W 11
th
St. Suite 100
Anderson, IN 46016
Ph: (800) 443-4859 Fax: 765-608-5235
Jul 02, 2014 | Parallax Power Supply Parallax 7300 Series...
Battery is installed properly and keeps blowing 40 amp fuse on the out put side.
Hi there, Ive had the same problem that came from a worn out wire that was toucing, this may be the problem.
May 26, 2014 | Parallax Power Supply PARALLAX POWER 7465...
Capacator in lower left corner is blown apart from an 220v generator connection.... where can i get a replacement capacator or board ?
The capacitors are industry standard items that can be cross referenced from the component markings, values, or part numbers referenced on the components through several national component suppliers such as Digikey, Mouser Electronics, or Newark Electronics. If a single bulk capacitor has blown, both should be replaced as the other will have been stressed and should not be trusted to be functionally sound.
Apr 11, 2014 | Parallax Power Supply Parallax 7300 Series...
Wiring parallax 7300 series converter
If the white wire is the large # 10 AWG on the DC output, connect it to terminal "D" on the backside of the DC fuse panel. The front side of terminal "D" carries the 12 volt system negative or battery negative wiring. Refer to the wiring label pasted to the inside surface of the drop open door for terminal locations.
If the white wire is the smaller #12 AWG, 120VAC "common" or neutral, connect it to the isolated neutral terminal bar in the 120VAC circuit breaker compartment where the other white 120VAC neutral wiring is connected. The 120VAC isolated neutral terminal bar will have a full length plastic insulator under it and will not be directly connected to the chassis.
Apr 12, 2013 | Parallax Power Supply Parallax 7300 Series...
Won't generate power after hooking to home electrical system
You have blown the stator and possibly the rotor due to back feeding
Mar 09, 2012 | Coleman Powermate Premium Plus 6250W...
Rv generator output, yet no power in coach. Called Parallax about Transfer switch, yet company says just reset the transfer switch, did now says error fault relay switch. Parallax ats501 why now there is a...
Check to see if you have power going into the switch. This can be done with a voltage meter at the terminals were the cable runs into the transfer switch. Do you have power at the generator plug?
Jan 06, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a new Generac 20KW Propane generator with a rtse 200A3 automatic switch. I had an electrician install the switch and make the connections from to the generator. The generator is blowing the 7.5 amp...
Sounds like the electritian wired something wrong. Control wiring for that generator should be:
N1 and N2 = 240 vac utility input
Wire 0 = ground
Wire 194 (15B) = + battery
wire 23 = transfer signal
Sep 02, 2009 | Generac Guardian 200 Amp Transfer Switch...
Parallax Power Supply 7345 Power Center Electronic Converter/Charger Logo
35 people viewed this question
Top Parallax Power Supply Electronics - Others Experts
Are you a Parallax Power Supply Electronics - Other Expert? Answer questions, earn points and help others
