Question about KitchenAid Kitchen Appliances - Others
Does not turn on
Lever does not stay down
Lever won't stay down. Have removed all screws and could take off top but handle on lever prevents this. How do I remove the end of the lever in order to get the top off to check latching mechanism?
My toaster turned out to have an electromagnet that makes its lever and the toast carriage stay down. It turned out that the problem with my toaster was that it was plugged into a faulty outlet. Unfortunately, I destroyed part of my toaster's darkness mechanism trying to understand its latching mechanism before I realized that it was not made like traditional toasters. So my first recommendation to you: try plugging it into an outlet that you KNOW works.
Feb 13, 2015 | Kitchen Appliances - Others
When turning left and I activate my turn signal lever it will not stay engaged. I have to hold the lever down while turning and when turning to the right, my lever will not disengage after the turn, I have...
I recommend that you will post your question under the correct category (Cars & Trucks) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
Jun 26, 2012 | Injen Chevrolet 2005 Cobalt 2.2L, No Air...
The lever on my rice steamer won't stay down any more, anything I can do?
Adjust ur THERMAL lever, underneath the cooker there is a SCREW w/ metal lever, adjust it till ther lever stays down!
Nov 05, 2010 | Aroma ARC7031G 6Cup Rice Cooker
The lever won't stay down
The lever will not stay down. Sometimes the lever will catch and other times it takes 6-8 times befroe it will stay down and toast the bread. Thanks....
Oct 16, 2010 | KitchenAid KTT570 4-Slice Toaster
"Down lever" doesn't stay down
You can try taking the toaster over to the kitchen sink and hold it upside down. Shake the heck out of it and you may dislodge something (like an old breadcrumb) in the switch. I've had to do this numerous times. You have to flip it upright, shake it, turn it upside down and shake it again -repeat until nothing comes out and nothing sounds like it's rolling around in the toaster.
Mar 14, 2010 | Kitchen Appliances - Others
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Lever on taoster will not stay down
I would just buy a new toaster...they are not that expensive. Check the intruction book first because maybe it's under warranty. Or if you bought it very recently, just take it back to the store. Most places will take it back even without a reciept if you tell them you just bought it and it's already broken.
Nov 22, 2008 | Kitchen Appliances - Others
My feed dog fell down and I can't get it to stay up.
Something I read made me realize that the owner's manual assumed you were looking at the machine from the back rather than from the front. I had been moving the lever in the wrong direction.
Aug 21, 2008 | Sewing Machines
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Dec 27, 2007 | Kitchen Appliances - Others
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Kitchen Appliances - Others Logo
89 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
