Question about Dell Computers & Internet
Monitor wont come on, switch is sluggish compared to previous performance
Monitor will not go on and switch seems dead! Is there any other way to turn the monitor on short of switch replacement? I'm not sure tha's the problem but it may be cheaper to replace than fix. Any thoughts??
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
It's not about the switch.
Posted on Apr 25, 2014
SOURCE: Open cover of Samsung Samtron monitor
remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
Posted on Nov 13, 2007
SOURCE: moniter
Back light generator problem...common.
2SC 5707 transistors died.
Posted on Jan 14, 2008
SOURCE: Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Posted on Aug 20, 2008
budmrtn
  • 11361 Answers
SOURCE: samsung 906BW monitor wont turn on, power switch
This model is released in June 2007, more likely to have bad caps by now, just other failed SAMSUNG monitors here: http://s807.photobucket.com/home/budm/allalbums
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Post back what you find.
Posted on Apr 03, 2010
Doc Rings
  • 9 Answers
SOURCE: Dell monitor white screen
Some people have disassembled the LCDs, and resoldered all cracked or corroded solder joints to get them to work again.
Posted on Feb 20, 2011
I have a tiny computer but after turnin it on it doesn't start, it just shows ''of mode'' on the monitor,so whats the problem?
Since the computer seems to turn on fine, the problem is most likely with your monitor or its cables. Make sure everything is connected securely. If this does not work, you will want to try plugging you computer into another monitor. The least likely, if the previous steps do not fix the problem, is that you're graphics card in the computer is dead and needs to be replaced.
Mar 16, 2011 | Computers & Internet
Monitor keeps turning on and off? it wont even show the screen for more than a second or two and then switch to black again.
your LCD inverter is almost dead. the monitor itself actually remains on, but just goes to black each time the LCD inverter cuts out, since this is what supplies white light to the screen.
In case you wanted The FP5315 Users Guide, or 3 other HP documents for the HP FP5315 LCD Flat Panel Monitor:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=324205&
Jan 05, 2011 | HP Compaq FP5315 15" LCD Monitor
Screen wont fire up, on/off button flashing in the on position.
try rebooting in safe mode (turn PC off ,then on again, and then press F8 as it powers up until it shows the boot menu) If the monitor doesnt show anythingat all during bootup..... then either the monitor is dead or the videocard is dying.
Jan 30, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
The sound/volume turned to mute automatically?
Assuming that you are using one, take the batteries out of the remote, then turn the sound up with the switches on the monitor. Tactile switches somethings get stuck. The mute switch could be one of them. If it is the one on the screen, check the "feel" of the mute button compared to the others. Damaged ones usually feel "flat".
Jul 18, 2017 | Computers & Internet
ViewSonic VA912 half screen dead after 30 minutes
first i confirmed that the problem was in lcd.then i predicted that some display chip on the motherboard are getting heat.due to which the display was performing irregular then i switch on A/C of my room.and the temperature was cool. and the monitor was working fine.
Apr 29, 2009 | IBM E54 (Pearl, White) 15 in.CRT...
Faulty monitor after one year
Hi Shirley,
In Singapore, Acer monitor is 3 years warranty.
If the your monitor is out-of-warranty, please consider replacing. It is cheaper than repair.
Performance life is normally around 2.5 yrs ++. Normal faults is due to manufacturing defects.
Dec 30, 2008 | Acer AL1916W 19" LCD Monitor
Emachine T3414 monitor
Turn off the computer and monitor. Disconnect the monitor. Turn on the monitor. You should get some indication the monitor is on, if not it is probably dead.
If the monitor seems to be on, try to enter the menu by using the buttons or knobs on the monitor. If the menu comes up, the monitor is probably good and you have a computer problem.
If you think the monitor is bad, hook it up to an operational computer. If it works, you definitely have a computer problem; if not the the monitor is definitely dead.
Either way try to have the problem resolved under the warranty.
Nov 01, 2008 | E-Machines eMachines Desktop PC
Monitor gone dead
does your tower turn on? just check if the monitor is the cause of the problem..
Jan 20, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
