Question about Coleman 9.9 HP Manual Start Outboard Motor 9.9 HP Manual Start Outboard Motor
Coleman outboard overheating
Outboard not pumping water, overheating
    Sergeant:
  • 321 Answers
You should change your impeller.
It is located at the top of the gearbox, around the vertical engine shaft.
First, disconnect the gear control. Underneath the steering bracket, you'll see a long nut with a counternut. ( Maybe you'll have to shift FWD or BWD to get better access ). Loosen the counternut 1/4 turn and then turn the long nut up ( 2 open box wrenches 10mm ).
Then remove the 4 bolts holding from lower to upper the gearcase ( just above the anti-cavitation plate )
The gearbox should drop down easily.
Then remove the 4 screws of the waterpump ( top of gearcase, around the long vertical shaft ). Lift the waterpupp housing, you'll get the impeller.
To reassemble the waterpump, grease the cup in the housing with PTFE or silicone grease, and while pushing the housing down over the impeller, rotate the shaft clockwise.
Reassemble all the rest in reverse order.
Check and adjust the gear shifting...
Posted on Mar 08, 2015
  • Fabrice Wolters Mar 08, 2015
    NEVER, oh NEVER run an engine out of the water!
Seagull water pump failure
Or if you want to do it yourself. There are videos to at the bottom link
  • British Seagull Outboard TRN40700 Water Pump Kit ... www.sheridanmarine.com > ... > British Seagull Outboard Spares The British Seagull Outboard TRN40700 water pump kit including the rotor, the joint plate and fixing bolts.
  • Tips & Tricks - Seagull Outboard seagulloutboard.com/?page_id=74 These tips & tricks are ideas contributed by a variety of Seagull Outboard enthusiasts ... This is best done by substitution of the thick pink water-pump gasket with ...
  • Seagull Fourty Plus, & Cooling Modification - YouTube www.youtube.com/watch?v=cfjpVoazL2Q
    • BY RTEDA
    • 3 MIN
    • 7.3K VIEWS
    2009-08-22 · British Seagull, GFPL series N7 (Dec. 1977). Added a siphon-effect water coolant improvement. With an added tube from the original water ...
  • Seagull FAQ www.britishseagullshop.com/faq.html Does the engine pump water? ( If it does its most likely the cooling system is fine) 4. ... HOW CAN I SOLVE THE ELECTROLYSIS PROBLEMS ON MY SEAGULL?
  • Seagull water pump failure Bing video
    May 09, 2016 | Boating
    Engine overheating
    Water pump, which is located in bottom shaft housing near the prop, could be going bad and not suppling enough water to cool the engine
    May 18, 2014 | Boating
    Water pump
    The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
    May 14, 2013 | Seloc Mercury Outboard Engine Repair...
    I have a 1980 evinrude outboard motor. It is overheating. We have changed out the water pump, took the thermostat out and checked it, it works fine. What else could it be?
    I could possibly give you a better explanation if I knew the horse power of the outboard. However hear is what happens to most "tiller" operated outboards. Water pumps are made from a pliable soft rubber which by the way needs water to lubricate it even if you just crank it over to check something, or fire it up for a few seconds on a dry impeller will destroy it. Most often a few pieces will fly off and enter the water cooling system and then lodge in one of the small passage ways blocking water flow. When a new impeller is installed the engine runs pumps water and overheats.
    Dec 05, 2010 | Boating
    Overheating to my mariner 200 outboard enging
    I would start with cleaning water intake and if you haven't re placed water pump impeller in last two years would do so now ,before you lose a weekend off the water,Hope this helped .
    Mar 23, 2010 | 2003 Mercury Mariner
    40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
    May likely be one of two problems:
    1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
    2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
    Sep 17, 2009 | Boating
    Mariner 25hp 2stroke outboard. runs fine when
    With what you said.get the water pump done.A little bit of rubber is cheaper than metal.If the motor has a few years on it,the pump does need to be replaced.If the motor overheated after a few minutes,the pump needs replacing now.Yours sounds like it's on it's way out.A bit of sand etc. can do a fair bit.Hope this helps
    Sep 09, 2009 | Boating
    8hp yamaha runs hot
    In most outboards, it will flow through the prop itself (through the inner prop). There should be a stream of water coming from somewhere around the back end of the motor itself, called a telltale, which visually shows that the water pump inside the outboard is pumping water up around the motor. If you cannot see this, then there is obviously a problem with the water pump or pump impeller that needs to be corrected to prevent the outboard overheating.
    Jul 04, 2009 | Light Outboard Motor Boat Bass Fishing...
    Coleman 9.9 HP Manual Start Outboard Motor 9.9 HP Manual Start Outboard Motor Logo
    294 people viewed this question
    Top Coleman Boating Experts
    ray gallant
    Bill Boyd
    Fabrice Wolters
    Are you a Coleman Boating Expert? Answer questions, earn points and help others
