Question about HP Pavilion A6120N PC Desktop
Check video cable
It keeps saying check video cable
    New Friend:
    Problem Solver:
  • 8 Answers
That's because the monitor is no longer sensed. Try removing the video cable from the monitor, then gently but firmly put it back in place. Tighten the nuts securely, but not so hard that you would need a tool to remove it. If the problem is still there, do the same thing where the cable attaches to the back of the computer. If that doesn't work, the problem is most likely with the video card. If you know how to do it and have a spare video card, you could try swapping it to see if the problem goes away, but at this point it's probably time for a visit to the repair shop.
Posted on Apr 21, 2014
2 Suggested Answers
SOURCE: Has black screen that says no signal input check
If you are so sure that cable is good and plugged in properly in both the end ( ie monitor as well as cabinet) and teh computer is turning on ... then you can try to turn the computer on in the safe mode
fore that when its turning on - keep tapping the F8 key on the keyboard and it will give you an option where you can select that you want to start it in the safe mode ..
once its on then you need to reduce the screen resolution for that
right click on any empty place on the desktop and go to properties.
it will open a window which says Display Properties under that look for a tab which says setting and from there you can reduce the screen resolution
You can get back to me if it does not help you
Posted on Apr 19, 2011
Hp w1907 check video cable
check your video cable is properly connected on bothe side
frist check RAM is properly inserted. remove RAM and clear PIN board with thiner and clear the slot with a brush then reinstall it.it may work if still problem check SMPS is working well or change it see any hardware which is connceted to directly with motherboard is not to loose. then problem is not solved. may be your motherboard faulty
Apr 01, 2014 | HP Compaq Presario SR1503wm PC Desktop
My yamaha receiver RX-V363 keeps shutting off and saying check SP cable
It is one ot two things, the audio output transistors or ic,s are shorted, or the speaker wires in the back of the surround sound are shorting.
Apr 08, 2012 | Yamaha RX-V363 Receiver
Acer LCD monitor keeps saying no signal after start up
please check if the display cable is properly placed, the reason it says no signal because there is no signal been detected to from your cpu, if the cable is properly placed pleased try to clean you video card.
Jul 02, 2011 | Acer Computers & Internet
It says "input signal is
it could be a bad dazzle or bad cables
Feb 28, 2011 | Pinnacle Dazzle Video Creator Plus Video...
Moniter keeps turning off saying no video imput
Hello and Welcome to FixYa!
Check that the Input signal cable is properly inserted in the VGA socket. Secondly the Primary VGA is properly giving display signals to the Monitor/LCD. Because there are cases in which VGA is the bottle neck of the trouble you are facing.
Cross check and update me with the status,
Best of Luck,
Do RATE the solution, If found Helpful,
Concerned.
Jun 13, 2010 | HP vp17 Monitor
Hello
I FIX LOTS OF COMPUTER, AND MY ADVISE IS. IT MIGHT BE YOUR COMPUTERS VIDEO CARD CAUSING THAT PROBLEM . ALSO CHECK FOR VIRUSES THEY CAN DO STRANGE THINGS.
Mar 17, 2010 | Computers & Internet
Why my hdmi cable keeps saying unsupported signal. check your device output
use a normal cable to connect to you tv and check the resolution that the hdmi is trying to output. if it wont display with the normal one then you will have to reset the video output system.
http://www.tipstrs.com/tip/1888/Reset-your-PS3-video-settings
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
Check video cable keeps reading and go off, but the power is still on
the screen on most monitors will go black if the cable connecting them to a device is lose or disconnected altogether. try the cables in the back the ones other then power cable
Apr 15, 2009 | Neovo F 415 (Black) 15" LCD Monitor
Monitor to tower hook up problems
Open your monitor's cover and plug out vga cable and check continuity of wirs this way-d314a67.jpg
Mar 26, 2008 | Gateway FPD2275W LCD Monitor
Monitor not working
These messages appear during if the video cable becomes disconnected or
damaged.(most likely you will need to replace it)
Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly
Nov 14, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
HP Pavilion A6120N  PC Desktop Logo
15 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
