Question about Taylor Model 608 Elite Digital Instant Read Thermometer
Nothing appears on the screen
There is no read out on the dial
Blue screen appears and message read I should installed bios
The BIOS must be installed or you would have nothing at all. Check drivers are installed.
Oct 07, 2014 | Computers & Internet
I have a singing machine, model STVG-1009, and the disk is not spinning and nothing reads on the screen. what could be the problem? how expensive is it to fix?
There appears to be a problem with the printed circuit board on these machines.
A possible fix is to remove the back cover then loosen the 4 screws holding the printed curcuit board.
Jan 28, 2012 | The Singing Machine Audio Players &...
The screen of my nokia 5800 XpressMusic is not appearing properly and therefore I can not use it. Please help me with it. Nothing can be read since the screen has the lights but it is not readable
have you tried to restart your phone? if not, kindly try it and if your phone is still the same way you can try restoring it to its factory setting by clicking the menu-->settings-->phone-->phone management-->factory settings and select yes or try to master reset your mobile by just dial *#7370# and accept but before that i suggest that you should back up your file first.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 19, 2011 | Nokia 5800 XpressMusic Smartphone
Sony ericsson c905 screen not working
GO TO THE SONY ERICCSON WEBSITE, PRESS SUPPORT AT TOP OF PAGE, SELECT PHONE ON LEFT (C905) then above the picture press software downloads, then press Update your product software, then press read and download, follow the instructions once loaded, remember to have the usb /sony cable ready as you will need to plug phone into computer, phone needs to be fully charged and needs to be turned off, good luck !
Nov 10, 2008 | Jabra T-Mobile Wing / Dash / SDA /...
Screen reads..."Mode dial is not in the proper position"
I had the same problem, so bought a few precision screwdrivers and took the back off. Be careful, but you can release the top section and on the bottom of the dial is a few plastic spacers which had squashed. I straightened these out, carefully put it back together, and this solved it. I think these spacers hold the electronin dial in place, hence why it comes up with " not in proper position ". If you fancy trying, it only took me 5 minutes and I know nothing about electronics.
Tom A
Sep 03, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Can not dial from my treo
Go to applications,choose Phone and the main screen of the phone will appear,then try to dial a number
Jun 11, 2008 | Palm Treo 650 Handheld
KE800 chocolate phone
the phone is the ke800 and no, i dont know why the screen doesnt work. i did read how others have the same problem. one day it worked the next nothing..dont have money for the plan..but these phones are too expensive to just up and quit on you..thank you
May 22, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Nothing appears on the LCD screen. What should I do?
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Taylor Model 608 Elite Digital Instant Read Thermometer Logo
451 people viewed this question
Top Taylor Plumbing Experts
Donni Steen
Tom Chichester
Are you a Taylor Plumbing Expert? Answer questions, earn points and help others
