Question about Sansui SLED2900 29" LED TV 1366x768, 60 Hz, HDTV
Code for sanui model sled2900d,e/f/h/i
I need the code for the comcast remote to get the volume button to work , along with being able to use the mute button. Helen
2 Suggested Answers
  • 520 Answers
SOURCE: need to find a code to work the tv/vcr combo from a comcast digital remote
Try the codes for Orion, Emerson and RCA as well as Sansui. Good Luck!
Posted on Oct 29, 2008
Mitsubishi CS-31205 TV Never had a remote for this great TV, but, accidentally pushed a button on my Comcast Cable remote and the TV is now in "Mute" mode. Not the Comcast box 'Mute' . Have...
You are supposed to be able to switch the Comcast Remote to TV mode and switch Mute on that remote to change back to standard volume. If that doesn't work try volume up on the TV. Otherwise if neither of those work then check Remotes.com for a replacement TV Remote.
Mar 09, 2011 | Televison & Video
Need to program remote, don't have codes
RCA TV/VCR Combo Model T09085:
Comcast Digital Adapter Remote (DTA) Code is... 00000
Comcast Universal Remote - Red OK/Select Button (DTC)
Code is... 21479. This code controls TV On/Off and VCR All functions. I could'n find code for vol+/vol- and mute.
Oct 23, 2009 | Televison & Video
Looking for remote codes for vizio sound bar and comcast remote
I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
Oct 16, 2009 | Televison & Video
Need code for Audiovox LCD TV (Model LCD1900W) for COMCAST DTA
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off
Aug 28, 2009 | Televison & Video
Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
Feb 19, 2009 | Samsung DVD-V1000 DVD Player/VCR
What is the 5 digit code for sylvania 26'' lcd tv
Go to comcast.com they have a remote link for codes
Dec 22, 2008 | Televison & Video
Comcast on demand custom dvr 3 device codes for sony dvd-hdx576wf
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Aug 06, 2008 | Audio Players & Recorders
Code to remote
try the code for a "sansui" brand, it worked for my tv
Jan 22, 2008 | Insignia IS-LCDTV32 32 in. Television
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Need TV code for Emerson HDTV LC320EM8A
I am looking for a remote code for the emerson LCD to work with the Comcast remote...any suggestions?
Dec 08, 2007 | Emerson EWL3706 37 in. LCD Television
Sansui SLED2900 29" LED TV 1366x768, 60 Hz, HDTV Logo
23 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
