Question about Thermador SGS36GS Gas Cooktop
No flame on exx low
No exx low flame on simmer control
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
This is generally due to blocked burner heads due to spills, remove it and clean it thoroughly before going any further.
Posted on Jun 11, 2014
How can I adjust the flame on the simmer burner to be lower? It seems to be too much flame for a simmer. Otherwise cook top is working great.
Where the gas comes into the stove, there is a regulator. Have a service person check the incomeing gas pressure after the regulator with a manometer. Sounds like you are getting too much gas pressure to the range.
heatman101
May 23, 2011 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
Need to remove the top of a JGP945BEK2BB to replace a part. I am trying to replace the red lens that shows the unit is locked.
after using the simmer portion a mini explosion occurs after about 10 minutes and the flame goes out. if other burners are on they also go out. only happens when simmer is on
Oct 31, 2009 | GE 30 in.Profile JGP945 Gas Cooktop
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
Jan 26, 2009 | Amana AKS3040 Gas Cooktop
Extra low burner that won't ignite
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Aug 10, 2008 | Thermador SGS36GS Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Burner goes out when cabinet door is opened!
i haven't worked on one of these models hands on but on most you can pull the burner **** and look inside you should see a tiny ***** in there hold the outer piece with a pair of pliers and take a tiny screwdriver and after turning the burner on turn the ***** to adjust the flame just enough so the suction doesn't blow the flame out on the lowest setting
Mar 08, 2008 | Cooktops
Thermador SGS36GS Gas Cooktop Logo
105 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
