Question about Whirlpool WED8300S Dryer
When drying the dryer seems to smoke and coils get red. how can i fix that problem?
  • 612 Answers
Check your cycling thermostat. Sounds like it's cycling on the high limit rather then the thermostat. While inside the unit, clean the lint out of the whole thing. Smoke is not a good thing. Where there is smoke, fire isn't far behind. Good luck!
Please rate solution.
Posted on Aug 28, 2009
Whirlpool Gold Ultimate Care II Gas Dryer takes to long to dry
sounds like ur t-stat is bad or maybe a thermal fuse. hard to say w-out diagnosing in hands on.
Jul 25, 2013 | Dryers
Dryer wgd5300, takes a long time to dry. seems
The burner is supposed to05245ec.jpg cycle on and off all through the drying cycle. Over time the operator coils 279834 get weak and quit. They are really easy to replace. This short video show a normal Burst of heat from a dry and the normal length of time it fires off
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 19, 2010 | Whirlpool WGD5300S Dryer
Coils get hot
Hi, as soon as you turn your dryer on, power is sent to these heat strips and they will glow red hot. This is normal. They will kick on and off through the drying cycle by several thermostats in the unit so it will not over heat. Nothing to worry about as you have 240 volts going to them.
Sincerely,
Shastalaker7
Apr 20, 2010 | Whirlpool LEB6300 Electric Dryer
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
Our drying is not heating up and its not drying the clothes whats wrong with it and how do i fix it?
our drying is not heating up and its not drying the clothes whats wrong with it and how do i fix it?
Dec 30, 2009 | Kenmore 62602 Electric Dryer
I have almost the same problem... but I have plenty of heat.
If it's takeing that long and your element (coil) is that hot your exhaust is probablly blocked it will need to be cleaned out.
Oct 05, 2009 | GE DLSR483EE Electric Dryer
Dryer does not dry as fast as it used too. Takes two cycles to dry a big load. Filters and exhaust are clear, and blower is still blowing. Looking in heat element, seems like botton 1/3 of coils don't turn...
Then part of the heating element is most likely not working because it is burned out or the high heat setting on the control no longer functions. Let me know the model number located most times inside the door on the wall of the door opening. That way I can Help you better, Thanks, Sea Breeze
Jul 13, 2009 | Whirlpool Dryers
Drying Cabinet above emits a smoky scent but there is no smoke
These cabinets seem like such a good concept.
While I have never worked on one, I would first take the back off (having disconnected the power) and look for a build-up of lint on the heat exchanger/heating coil assembly. Check that ducts are free of built-up lint and fans turn freely.
Lightly lubricate the motor shafts with a drop of machine oil. reassemble and run a test cycle monitoring carefully (keep a fire extinguisher at hand and a clear path to exit the building, have ready access to a telephone, know how to turn off the main power in your home). You will likely need none of these precautions but it's best to be safe and prepared.
Most dryer failures are related to lint build-up leading to excess heat. Clear vent ducts frequently, clean out the inside every few years, lubricate lightly at the same time.
Jul 07, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Whirlpool gas dryer wont heat up
Hi!!! you seem to have a problem with the coil boosters..located above the gas valve..Its shown here .Good luckk..8035205.jpg
Jan 21, 2009 | Whirlpool LGR6636 Gas Dryer
Dyrer gets to hot
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
a454a
Jan 04, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
204 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
