SOURCE: front wheel bearing replacement
Remove the lugs than disassemble the brake calipers remove the disc take a 3lb sledge hammer and swing it and hit the back side of where the lug studs are sticking out
SOURCE: speed sensor on a 05 escalade
Hey Joe, unfortunately, because your escalade is so new (05), there is not much info available yet online as far as free info goes. I checked a couple of sites and no luck. However, for about the cost of a manual, u should be able to access the speed sensor info and MUCH more online @ either 'alldata' or 'eautorepair'. I will do some more research on it tonight to see if I can find that info, but I'm not too hopeful. Is the escalade AWD?
SOURCE: ligts not working on steering wheel for 2006 escalade
If half are working, then most likely the other half are simply blown bulbs that just need replaced. A blown fuse would normally cause ALL the lights in that section to go off, not just half.
SOURCE: pitman arm 2000 escalade
I'm in the middle of doing mine now. The steering box needs to be pulled out of the truck. Arm will need a puller to be taken off the output shaft of the steering box.
SOURCE: Lock steering wheel...Key won't turn in the ignition
Make sure to push the brake firmly with you foot. I do this all the time.
