Question about Furniture
BUYING AFTER LAY DOWN
IN SHANGAI YOU GET INTO THE GAME AFTER YOU HAVE LAID DOWN THE REQUIRED RULE. CAN YOU BUY AFTER THIS
How do you end the game of 500 rummy /? IS IT THE FIRST TO 5OO OR DO YOU SEE WHO HAS THE MOST POINTS
Here are the rules as per the Bicycle Paying Card Company:
The Pack The standard 52-card pack is used.
Object of the Game To lay matched number sets of 3 or 4 and/or sequences of 3 or more cards of the same suit to be the first player to obtain 500 total net points.
Rank of Cards
Ace (high or low), K, Q, J, 10, 9, 8, 7, 6, 5, 4, 3, 2, A.
Card Values/Scoring Score points by laying down and laying off cards as in regular Rummy, in matched number sets of 3 or 4, and in sequences of 3 or more cards of the same suit. For example, three or four 7s can be laid or a sequence of 3, 4, 5 of diamonds can be laid.
When any player gets rid of all his cards, the play immediately ends. Each player's score is then figured as follows: The player is credited with the point value of all cards that the player has showing on the table. From this figure is subtracted the point value of all cards remaining in his hand. The difference is added or subtracted from the player's score.
For example: If the cards showing for a player total 87 points, and the cards left in the player's hand total 90 points, 3 points are subtracted from the player's previous net score.
The first player whose score reaches +500 wins the game and collects from each opponent the difference between their final scores. If two or more players reach 500 on the same hand, the one with the highest score is the winner.
The Deal Deal seven cards to each player (except in the two player game, in which each player receives 13 cards). Place undealt cards face down in the center of the table, forming the stock. The top card is turned face up and is placed beside the stock as the up card to start the discard pile. The discard pile should be slightly spread, so that players can readily see all the cards it contains.
The Play Each player, beginning with the player to the left of the dealer, may draw either the top card of the stock or any card from the discard pile.
There are two conditions when drawing a card from the discard pile: 1) the player must take all the cards above the selected card and 2) the drawn card must immediately be used, either by laying it down in a set or by laying it off on a set already on the table. The remaining cards taken with the discard may be melded in the same turn or simply added to the player's hand.
Each player in turn, after drawing but before discarding, may lay down any matched set or may lay off any card that matches a set already on the table.
Cards that are laid off are kept on the table in front of the player. Sequences may not "go round the corner"; thus, A, K, Q or A, 2, 3 may be melded, but not K, A, 2. - See more at: http://www.bicyclecards.com/how-to-play/500-rum/#sthash.1oRfJip8.dpuf
Dec 02, 2015 | Toys
What is the best way to lay down the clear coat over my finish coat on the fender I just painted but ruined when I shot the clear coat?
Refer to the paint manufacturer's data sheet to ensure the new gun has the right setup for clearcoat.
Could be the new gun was supplied setup for spraying a high solids primer or something that needs something like a 0.7 mm fluid tip. Clearcoat would need a 0.4 mm tip, an appropriate needle and a different air cap.
Data sheets are very valuable things. Don't forget to pick one up when you buy spray paint. A viscosity cup is another useful addition to the tool kit along with a graduated paint stirring stick.
Nov 24, 2015 | Air Tools & Compressors
Slate bathroom tile
First clean floor down to plywood. Then buy mastic, notched trowel and tile spacers from hardware store. Lay out tile in the pattern you want by cutting them with a tile saw you rented. take out dry laid tile and mastic a small area and install til making sure you press the tile into mastic. Insert spacer and install next tile.
May 16, 2013 | Home
GE model GTS22WCP can I lay it on it's side or back to transport?
it is not recommended to lay an appliance with a compressor, the reason is that the compressor oil will run to one side and the appliance will not function properly. i have heard that if laid down the make sure to stand the appliance upright for several days before plugging it in.
Aug 08, 2012 | GE GTS22WCP Top Freezer Refrigerator
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
I about to buy a stacked washer/dryer unit. Can it be laid down in a pickup bed to move, or does it have to stay standing up?
You should bne OK to lay it down on its side - either one. Just make sure you line the pickup with some blankets etc so that you dont ruin the paint on the journey.
Oct 15, 2009 | GE WSM2420T Top Load Stacked Washer /...
Laid down to transport and wont start need to know where to find tilt switch
Never lay a bike down for transport. And there is no tilt switch.
Sep 25, 2009 | 2001 Suzuki GSX 600 F (Katana)
How long do i wait to connect the fridge after I moved
Rule of thumb...if you laid fridge down, stand it up and leave unplugged for same amount of time fridge was laid down. If old fridge, and will not come on after above method, it is possible compressor motor has fallen out of mounting isolators inside compressor case. If so, compressor may hum and get hot but not cool fridge. This means you may need a tech to diagnose further, but probably cannot fix without replacing compressor. Only a qualified tech can diagnose this for sure.
Jul 23, 2009 | Refrigerators
Replacing power cord
General rule of thumb on dryer gord replacement. At the tip of the cord that connects to the power block, the metal connector rings have a "FLATTER" than other side if you lay it on the grond. Just be sure that the middle wire goes to the negative as it is laying flat, the other two will sit right in place.
Mar 16, 2008 | Dryers
Furniture Logo
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
