Question about Belkin Computers & Internet
186 i have a belkin 186 when i first set it up i had wireless. how do i get the wireless to work again
My wireless laptop not working
Try resetting your router and re-configure it again.
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 18, 2013 | Belkin (F5D7230-4) Router (587009)
I had to put my computer back to factory settings and now my Belkin wont go on wireless.It does work if i plug cable in.Is there anything i can do?
HI,
I see you set Windows back to defaults as you mentioned and now your Router will not go Wireless.
First Restoring Windows Back to Factory Defaults will not reset your Routers Settings to Defaults together with Windows.
So Most Probably the issue is since you restored windows back to factory defaults you may need to install the Wireless Driver again on the Machine / Computer to make your computers wireless card work again and be able to detect and connect to your Belkin Router.
try a difefernt device that can connect wireless to your Router or maybe a different Laptop to see if the Belkin is working fine wireless.
If any other Laptop will not detect the Belkin then try turning the Wireless Radio ON again in the Router Settings of Belkin.
But I suggest to check all your system drivers if installed for it to be wireless capable again on the issue, Restoring Windows back to Default will not change anything in the Belkin Router. I believe this is a Driver issue on the Wireless card of your Computer.
You mentioned the system does work if plugged in Wired right, check your drivers install every driver that needs to be installed from the Manufacturer Website of your Computer for proper and compatible drivers.
Have a nice day.
Aug 23, 2011 | Belkin N Wireless Router wireless router
My belki router cant work on my computer
Try RESETTING the Belkin back to the defaults and then configure it again.
Press and hold the pinhole RESET button at the back of the router and thenpower for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open abrowser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
May 26, 2011 | Belkin Basic Wireless Router
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin wireless G
You need to run again the set up cd for it to reinstall the card back and to make it work again on your computer....
Jul 03, 2008 | Belkin Desktop Card Network Adapter
Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a belkin n wireless router keeps freezing
First step of solution would be performing Reset. Press and hold the reset button about 30 seconds and release. Check again. If you need customized settings just type 192.168.2.1 in your browser and get into settings.
If issue persist please post for further troubleshooting.
Good Luck
Jan 24, 2008 | Belkin (F5D7231-4) Wireless Router
Wireless router belkin n1
Right click on the network icon in your task bar and click view wireless networks, then when all the networks show delete them all and close the window, next, a pop up will say found wireless connections click the icon again and look for your connection in the list and click connect and enter the pass phrase
Nov 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
16 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
