Question about Panasonic AG-DV1000 Mini DV VCR
Cpsman motor
I need a new motor
  • Panasonic Master
  • 1,511 Answers
That sounds good...go for it.
Posted on Jan 22, 2015
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
What causes a pool pump motor to overheat
Blocked or clogged water input line
Sucking air from a leak, not enough water thru system
Excessive debris in strainer baskets
Filter needs to be backwashed
Filter needs new sand or new cartridge
Filter needs to be taken apart and "fingers" cleaned
Filter Pump Impeller is obstructed
Filter motor is in-correctly wired
Filter motor bushings need replacement
Filter motor bearings are worn
Filter motor is "shot"
Apr 16, 2013 | Emerson Pool & Spa
My engines dead and i need to put a new one in, i have a 98 chevy cavalier 2.4 twin cam engine currently in it (dead)
are you sure the engines gone? have you had at least 2 certified mechanics tell you that you need a new motor? in todays age, some people do lie for money.sad but true. try calling a local mobile mechanic and have them come out and diagnose it {the motor} bad. unless you're mechanically qualified to diagnose it yourself. then, try a pull a part junk yard for used motor or a local part yard for used motor. if you do prefer a new motor,you can order a new motor from dealer,auto-zone,advance auto parts. the new motor price,i do not know. the used pull a part motor,i do. the motor cost is with warranty,is $210.00 in tn. in ga. thats you pull the motor yourself. the motor from a part yard that pulls it for you can be anywhere from $500.00 to $950.00 depending on how many miles are on the engine that's being removed. 1st myself, i would need to know for sure that my motor is really bad.just like a dr. before doing surgery,you need 2nd opinion. sorry,just the way i am. if you're mechanically inclined and can make the correct diagnosis,you can find a good used motor. if not and you're trusting someone else for parts,labor,i suggest you consider the cost of replacement,the cost of the labor,versus the cost of the entire vehicle replacement into another car. that's only being honest. good luck and thank you for choosing fixya.com!
May 06, 2011 | Chevrolet Cavalier Cars & Trucks
The motor blew up, need to replace it. new or
A new motor will cost you 1000s . A used one will do if you are short on money. Places that sell used motors usually have a limited warranty on the motors they sell. They do a check up on the motor and refurbish it. they give you time to take it back in case it fails or anything else.
Nov 27, 2009 | 2001 Ford Windstar
Whirlpool dishwasher noisy needs new motor
You may not need a new motor. If it is "buzzing" it may need a new small run capacitor - that can dry out and fail.
If the pump is noisy (but working) it may need clearing - or if worn - replace the pump.
Only replace the motor if the bearings are badly worn or armature damaged.
Sep 30, 2009 | Home
How do I install a new windows motor- to include the cable drum (drivers side). The old motor burned up and the cable broke. Thanks Hans
You'll need to buy a new motor and regulator. You can go used or new, it's up to you. The regulator will include the cable.
- Remove the interior door trim,
- Disconnect the power cable from the window motor,
- Remove the window bump-stops (one at the front, one back),
- Remove the glass window from the regulator (two bolts),
- Slide the glass window out of the top of the door,
- Remove 3 nuts from the window motor,
- Remove all window regulator bolts,
- Slide the motor & regulator assembly out the top of the door.
- Mount your new motor to your new regulator,
- Install the new motor & regulator assembly in the reverse order.
Jul 27, 2009 | 2003 Hyundai Tiburon
Old capassitor has 3 prongs new capassitor has 2 prongs
The old motor relied on a leg off of the ol cap marked FAN. No need to bother with it anymore because the new motor probably has a different cap rating therefore it needs its own wittle capacitor. Cute ain't it? That new motor will probably have a common wire to connect to that Old cap at the C mark on it though. It will have 2 brown wires to connect to that new cap for it. (insulate that cute little cap to prevent any shocktastrophies) The black wire will of couse go to wher the old one did on the contactor. Read a little ditty I affectionatly wrote for further info entitled 'old motor had 3 wires new motor has 4 WTF"
Jun 06, 2009 | Heating & Cooling
I have a Kenmore series 80 that I bought it used two years ago, it now has a bad motor, it was manufactured in '96. I replaced the motor coupling a month ago. My question is, is it worth replacing the...
hello, i'ld say buying a new motor is far cheaper then buying a new unit unless the maching is in bad condition for a new motor your looking at anywere from 50.00-175.00$ depending on the model number of your machine. good luck on making your decision, and if you decide to buy the new motor and need help finding one let me know i can help you find the motor you need.
Mar 22, 2009 | Kenmore 24442
Bike wont start
If you can't find another similar connection on the new motor, you might need to swap heads (if it's the same exact motor).
Jan 14, 2009 | 1999 kawasaki ZX-9R Ninja
Panasonic AG-DV1000 Mini DV VCR Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
