Question about Dometic Rooftop RV Air Conditioner
How to recalibrate a 331389.015 rv thermostat
Read out is different from read tempiture
    Genius:
  • Dometic Master
  • 1,363 Answers
Internal sensor issue or connection between t-stat and sensor.
Posted on Aug 24, 2015
This thermostat is mounted mid-wall on a brick wall and consistently reads 4 degrees warmer than 2 other thermometers in the room. Can the thermostat be recalibrated? How?
A manual for the thermostat is needed to recalibrating if doable, thermostat model number and brand needed to get the right manual.
A thermostat mount location should be planned. Any holes leading into the wall should be sealed, in other words, the thermostat needs to be insulated and isolated from fake temperature readings, no back drafts or not heat or cooling sources near by.
Jun 23, 2015 | Heating & Cooling
What tempiture does my pac a110 delonghi have to be on to get cool air
The temperature has to be lower than the room temperature it's in. Most thermostats are set to 76 degrees or lower.
Jun 27, 2014 | Heating & Cooling
Why does temp in rv not match thermosat
get a good quality thermometer and take a reading at thermostat. most thermostats have a way to calibrate the reading on the face.
Jun 20, 2014 | Coleman Heating & Cooling
Will not start at all not even just the fan
More info? Sure you have 120VAC to unit? Ceiling controlled or thermostat on wall, and what type of RV is it in makes a difference as well.
Oct 22, 2012 | Dometic Rooftop RV Air Conditioner
How do i wire analog thermostat to digital
You need to get a different thermostat.you can change an analog thermostat to digital, but you have to replace the motherboard with a digital compliant one. You can't just change the thermostat. Your best bet is to put back the old thermostat or upgrade to a different compatable thermostat
Jan 20, 2018 | Dometic Rooftop RV Air Conditioner
Dometic ac with atwood 1h2c thermostat will not come back on
Just a guess, as I am not familiar with the solar assist, if the stat is wall mounted I would remove it and verify if there is wither standard batteries, or a "watch" style battery. hope this helps
Jul 27, 2009 | Dometic Rooftop RV Air Conditioner
Reddy Heater 125t won't restart on its own after first cycle.
Sounds like a bad thermostat! (A common problem with this model) replace and it should work again!
Jan 30, 2009 | Desa International RH125AT Utility Heater
Dodge caaravan not heating up
you can still re calibrate it .. the codes will be displayed as flashes of the lights on the panel
Jan 16, 2009 | 2000 Dodge Caravan
Thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
95 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
