Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Not getting hot water
Machine asking help not getting hot water
  • 4 Answers
Hot water valave faulty if your hot water tap is open and can pass water. Otherwise fault inside the control board. It also can be fixed but first look at the hot water valve and the btap.
Posted on May 24, 2014
The water isn't getting hot
Hi Carl:
First, a question for you......
Did you just install this washer, or maybe do some maintenance?
The reason I ask is that there are 3 possible reasons the water is not getting hot.
1) There is no hot water available at the supply.
2) The supply hoses have been reversed and you're getting cold water when the machine thinks it's getting hot water.
3) The settings on the machine are requesting cold water. Check the dials.
Hope this helps.
Cheers.
Feb 23, 2016 | Washing Machines
Can I hook the wash and rinse to cold water hose?
Not sure what you are asking. If you want to wash and rinse you clothes in cold water only, there should be a water temp selection switch to allow you to do that. If you are asking if you can hook cold water hose to both ports on the washer back the answer is yes but it is easier to just cap off the hot side of the water valve on the back of the machine. Most machine water inlet valves are a 3/4 thread garden hose connection. Go to a hardware store or a Lowes/ Homedepot and ask for a screw on cap. They come in both plastic and brass. If you do cap the hot side of the inlet valve, make sure your washer has a cold only setting for wash and rinse and keep it set there. If it gets moved to hot nothing will fill or run.
Apr 15, 2015 | Washing Machines
My CVA620 machine asks to "expel air " but
keep holding the hot water button down until you get a steady stream of water with no air. if you continue to get the error message after the water comes out, you will need to check the flow meter. if water never comes out, you have a leak inside the machine, a pump issue, or a blockage in the water path. That machine uses the same pump for steam and hot water, so if your steam is working, your pump is probably good. Blockages usually occur from not descaling properly. That machine is prone to leak at the hose fittings. the original o rings were black rubber, and failed fairly early. the replacements are red silicone and last much longer.
Jun 12, 2011 | Miele Coffee System
What is a LF code on a Kenmore Oasis washer?
LF( long fill) shut water of clean water inlet screens//Turn water back on check for leaks test machine. screens are also in water inlet valve were hoses go onto machine///note both hot and cold must be turned on to that machine to work right Good luck if i helped please vote...need more help just ask..
Feb 03, 2011 | Kenmore Washing Machines
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
I have a Kenmore 24032 \ 24036 Top Load Washer.
Sounds like the water faucet may not be turned on all the way, or maybe the inlet screen on the washer is clogged. Some hoses have a screen in the one end too. Either way it appears to have a restriction somewhere.
Dec 28, 2009 | Kenmore 24032\24036 Top Load Washer
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
Nead help pleace
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 15, 2009 | Saeco Royal Digital Plus Coffee...
Machine says ventilate
Jan 11, 2009 | Saeco Royal Digital Plus Coffee...
Super hot water out of the group head on my Rancilio Sylvia
My Rancilio Silva is not making the water or steam hot anymore. Is it fairly easy to replace the heating element?
Dec 29, 2008 | Rancilio Silvia Espresso Machine
Washing Machines Logo
67 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
