Question about EliteGroup A530 Notebook
Monitor problems When powered on, whole system boots up but screen then turns black. If I enable VGA mode then screen turns on. On VGA mode, I tried changing the settings to 16 bit etc..screen turns to black again and I have to restart the whole process and enable VGA mode again I then tried plugging in a different monitor...no problem at all.
  • 20 Answers
Hey thr may b 2-3 prblms. i hope, first check the latest driver fr ur motherboard.. install n ckeck whthr th eprblm is solved or nt.. second set ur BIOS setting to default.. it seems tht someone had changed the BIOS setting.. n third.. go to monitor setting..(on monitor thr r few buttons) set thm to default... i hope ur prmblm 'll b solved.. check it out... n start ur windows on normal mode alwaz...
Posted on Feb 21, 2008
  • 520 Answers
Wrong or incompatable display drivers.update or re install
Posted on Jan 10, 2008
My monitor boots up with computer, but turns black when it gets to the desktop. if i turn the monitor off, then on again, it stays on for 2 seconds then turns black. can someone help me?
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Nov 17, 2011 | ViewSonic VX2235wm LCD Monitor
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
GeForce 9400 gt, black screen problem
It looks like your graphics card changes the screen resolutions and/or refresh-rate to something beyond your monitor's capabilities.
After installing the drivers and the screen goes black, restart you're computer and press F8 to get the Windows advanced menu boot and choose "Enable VGA Mode".
When booted into Windows, right click on the desktop and select "properties", select the tab "Settings" and pick a really low resolution like "1024x768" and press the "Apply" button (but don't reboot yet when asked to). Next press the "Advanced" button, then select the tab "monitor" and change the monitor resolution to "default" or 60Hz.
Now restart your system and see wether Windows will boot normally. If so, you can change the resolution and refresh-rate back to you preferred values. Whenever you pick a too high resolution or refreshrate the screen will turn black again, but don't worry, don't press anything and just wait 15s, after which Windows will roll back to the previous setting ...
Aug 16, 2009 | Computers & Internet
Out of range
may ber it is screen resolution issue.
When you power up the computer press F8 key then enter in enable vga mode.
Then change screen resolution to 1024*768 then apply AND ok.
Jun 26, 2009 | Westinghouse L1975NW Monitor
Computer screen blank
u have to need reset bios .
Open cpu cabinet and find mother bord pull cmos cell for 15 minutes from mother bord.
then bios is reset.
Tehn start computer problem still arisde.then when u power up the computer press F8 key then enter in enable vga mode.then go to dispaly property and change screen resolujtion to 1024*768 then apply and ok.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Dell 1200 Inspiron OS boot problem
Two things you should try to resolve this issue: -
  • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
  • If this works there is no need to try the second option.
OR
  • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
  • Select the option to Boot to safe mode.
  • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
  • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
  • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
  • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
  • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
Nov 15, 2008 | Dell Inspiron 1200 Notebook
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Samsung syncmaster 910t won't display
i have a solution try to check all capacitors in power supply section then replace it. ^_^
Sep 09, 2007 | Computers & Internet
Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
Apr 28, 2007 | XFX GeForce FX 6800 (256 MB) Graphic Card
Monitor goes blurry, colours/pixels start shaking across screen
Do you have your screen saver enabled, i so turn it off and se if it still does it. Secondly boot your pc in safe mode(pressing F8) on boot up and select start windows in safe mode. See if the monitor still does it, if so a monitor fault or loose/faulty vga lead. If it is ok then your graphics driver may be corrupt and need re installing.
Dec 30, 2006 | BenQ FP71E 17" LCD Monitor
Open Questions:
EliteGroup A530 Notebook Logo
87 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
