Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a 20hp turbo twin cylinder, 42" w/ 6-speed manual transmissiom. I just replaced a broken drive belt and when I started the mower the gear shifter was very hard to put into gear and the clutch would not disengage the transmision. I adjusted the clutch but this did not fix the problem. Also when the mower is running in gear, I can not change gears or put it into neutral. When the mower is turned off I can move the shifter into all gears. I have to turn off the mower to stop it and change gears. Any suggestions? Thank You
  • Dwain Pippen May 11, 2010
    What is the model number and what was the belt number you bought?
    New Friend:
  • 4 Answers
Reajust the clutch 1-9/16
Posted on Mar 11, 2013
  • 32 Answers
I think that it is not imposible to switch gears it is just very hard. i had that problem once too!
Posted on Jun 21, 2009
Only starts if mower lever engaged (without drive belt)
Sounds very strange but i would guess either a micro switch or one of the relays behind the dash.
Dec 16, 2017 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
I have a 1998 Craftsman 19.5 HP opposed twin turbo, and it wont start without taking the right plug out, which releases compression, and then put it back in, and the cylinder will fire and run accordi
You might try putting an inline valve in the fuel line feeding the carburetor or simply clamp the line shut to see if that works.
It sounds like hydro lock due to fuel getting into the cylinder when the engine is not running, Briggs had an issue with it along with others, some (like Honda) have a solenoid in the float bowl to stop the fuel flow. If this works install the valve, shut it off and let the tractor idle a minute before shutting down the engine
Sep 19, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Govenor keeps breaking gear on my 20hp briggs and stratton v/twin intec
when you replace the governor gear are you inspecting the pin that it rides on to see if it is bent? also are you inspecting the gear that drives it for damage a chipped tooth on the drive gear will chew up the driven gear
Jun 12, 2012 | Garden
Mower starts goes in gear but will not move
Sounds like the drive belt is either off one of the pulleys or is broken.
Aug 07, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lawn tractor, engine model 42A707, starter spins but won't start engine; noted starter gear on top is worn down. Need help to either replace whole starter assembly with gear or just gear?
I had this same problem with a twin cylinder B & S engine and was able to get just the gear drive replaced without replacing the whole starter. Hope this helps you
Nov 10, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a MTD yard machine, 42 inch ride on mower. 18.5 hp v twin briggs and stratton motor.7 speeds. The model details under the seat are missing so difficult to identify. I brought it secondhand and was...
find your local mtd distributor, the fact that it is an 18.5 v twin briggs and the 42 inch cutting width will tell them what model you have, then you can go to mtdproducts.com and order a manual, or get it from the distributor, serial number or model number will get you a manual or parts book
Oct 28, 2009 | Mtd Garden
Large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Jul 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20HP , can't stop freewheeling,
Sounds like your problem is the key in your rear wheel is missing or sheared, you have to remove the wheel @ tire assembly ,pull rubber cap off then clip to remove if one of the keys is sheared or gone it will go into gear and the brake will work ,but they will only stop the shaft without the key it will not move or brake becuase its not attached if you know what I mean.
May 11, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
678 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
