Question about Bush BTU500DTR 500GB Twin Tuner Freeview Recorder PVR
When recording one channel i cant watch all the channels
Unable recieve all the channels
Unable to watch separate channel when recording another on LG RHT497H. Question is can you watch another channel when recording another?
I scanned the entire manual for your recorder and found no mention of simultaneous dvr functions as you specified, so I have no choice but to say no you cannot...sorry...
Aug 27, 2012 | LG RHT497H Digital TV Recorder with 160GB...
We cannot watch a show on another channel on other
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
Jul 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Recording on a STB and being able to watch a DIFF channel.
It is possible to record a channel and watch a second channel. If your cable vision has digital-only signals, you will need a Digital tuner or a second cable box.
If your cable has conventional channels still, you can buy a splitter and run the cablevision to the TV and the CableBox at the same time.
Switch to the TV tuner, you see cable.
Switch to the recorder (connected to the CableBox) and you see what you can record.
Mar 28, 2010 | Televison & Video
Is it possible to tune the channels of an integrated freeview digital box within a tv to a recordable dvd player
No!
However, i see what your trying to accomplish - being able to record the freeview pictures you recieve form the Sony inbuilt tuner onto the recorder.. whilst being able to watch a different channel..?!
Well, you cant. If your Recorder has an inbuilt digital tuner then of course this would solve your issues, whereas if it is purely an analouge recorder and your in an area that has switched over then youll need some new hardware unfortunatly,.
Phone Sony on 0845 6000124 local rate number for more advise
Nov 14, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
May 29, 2009 | LG RH177 DVD Recorder/HDD Recorder
Cant work out how to use the two tuners to record and or watch two channels at once
you might only be able to watch this in a dual monitor type setting good luck
Apr 17, 2009 | Computers & Internet
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Televison & Video Logo
12 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
