Question about Frigidaire FAX054P7A Wall/Window Air Conditioner
My window unit fell out of the window and hung by the power cord that was still plugged into the wall. I was able to grab the cord and pull it back up. I reattached the power cord and now every time i turn on the power it trips the breaker. is this the shorted power switch where can i get one.
  • rnkhughes Jun 15, 2009
    the ground (green) wire actually broke in two and the other two leads pulled loose from the switch where they were the wire ends pushed onto the prongs. the rest of the rubber insulation is in tact all the way to the wall. all three wires are separated by the rubber insulation on the power cord. I used a wire splice and reconnected the green wire and repaired/replaced the the other two wires onto the switch.
  • 520 Answers
Its most likely is not the switch. It is most likely the cord though. Due to the excess strain on the cord it has probably cut through the rubber coating on the wire and connected to the frame and grounded the hot lead. Fix the cord and you may have it handled.
Posted on Jun 15, 2009
  • Chris  Jones
    Chris Jones Jun 15, 2009
    Then it is the switch. Try looking on www.Appliance411.com and that site will direct you to thousands of other sites that you can order parts from. Good luck.
    New Friend:
  • 12 Answers
I know this post is super old, but it seems to me that if the power cord were damaged as chris jones suggested then it would trip the breaker immediately upon being plugged in. More likely is that an internal component got knocked out of place and created a short that trips the breaker only when the unit is turned on, energizing the loose or bent component. This would be something like the electric leads of a fan bumping into the frame, or any other inumerable possibilities.
Posted on Jan 03, 2015
Hand unit will not stay on wall unit when hung on wall Model 1100
Usually you would post this in another catagory but this is fine . The slim line wall unit should have a little mechanism that you pull up on by the ear area on the wall unit that allows the hand unit to rest on if not remove the wall unit and see if the hanger is on back side of unit.
Apr 11, 2013 | 1100 slimline corded phone white
Need wiring digram
Some units the cord is actually detachable, if you don't think this one is, contact your manufacturer to see if they offer a replacement cord that you can purchase. Some do, some don't.
Sep 06, 2012 | Frigidaire FAC127S1A Air Conditioner
Somebody hung my TV for me but, didn't put the power cord in so, I'm trying to navigate blindly, it's hung on the wall, to attempt to plug in my power cord but can't find it. Can you give...
Tries look near the square arm plate that have four screws holding the tv look for a hole with 3 steel prongs that ur tv a/c hole for power cord hook up.But if the tv it is very closed and hook up tight and flust to the wall will not able to hook up a/c power cord must take off wall to be able to hook up a/c power cord.
Aug 27, 2011 | LG 42LC2D 42 in. LCD HDTV
Wiring for Goldstar R5050 window A/C
Yes I accidentally drop my Gold Star Model #R5050 out the window while installing it. I opened it up and the two(2) white wire are off and I don't know were they go. I try to connect the to the empty terminals and I got a spark out of the outlet. Can you please help me....
May 13, 2010 | Goldstar R5050 Air Conditioner
My power cord fell off. Took off the back of the
there is a small board with a small transformer . the plug is located next to that small transformer. if the cord originally came from the right hand side if you are looking at tv from the back. the plug is on that right board. if the tv cord came from the left side, the plug is located on the main board in the front of tv. the plug in both situations are the same, it is white in color and has 2 or three pins sticking straight up.
Nov 15, 2009 | Sony KV-32FS13 TV
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
The power cord hard to unplug from back of tv for wall mounting job
step-1.
first switch off your tv unit and if possible switch off yuor main switch also
step-2.and pull out the plug bu holding the hand inth end of plug not in wire .
still you have the problem
follow step-1. and using wd 40 liqiud (available all electronic shops ) apply between wall socket and juntion of plug
and wait for five minites
then try step-2.
finaly remove wall socket and try it now and remove the plug.
Oct 26, 2008 | Electronics - Others
Panasonic pt-53wX42, power wont stay on. Turn on, no picture then it will turn off by itself after 5 seconds. The red power button will flash on and off until I unplug unit and start the whole process...
I'm no expert, but I'd start by taking a "VERY GOOD LOOK" w/magnifing glass if possible , @ UR Wall Outlet Power Cord. Change to different wall outlet. Ur Power Cord "should" just pull right out of the back of your TV. If nothing in those places, then take off back panel (or part where power cord plugs into TV & AGAIN inspect area around where power cord attached for, yeah, that's right, the dreaded black area around plug-in area. Maybe it's just a bent prong. Any other funny things going on that U didn't mention here? Good Luck Leonard aka quikstudy@cox.net
Jul 23, 2008 | Televison & Video
Frigidaire FAX054P7A Wall/Window Air Conditioner Logo
378 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
