Question about Nintendo Wii Console
Doesn't the charge psyclone px6502b the inductive rechargeable batteries that it came with
When I put the batteries to charge, it just does continues fast blinking
The battery life is VERY much shorter on my phone than it used to be. I'm having to buy new ones every 3/4months? What's wrong? I always buy the best possible type from a reliable supplier.
battery life depends on 2 things
the amount of time you spend on the phone and the number of apps you are running
and the level of charge at which you recharge the phone
Recent questions put to a phone repair shop got the answer that 3 days from a fully charged battery was exceptional as most only do 1 day on normal use and less if watching live streaming
as to the level at recharge , batteries have a habit of developing a level memory and will not charge past that point
So if you continually recharge at almost flat, and allow for a full recharge , you get full battery life
at the other end of the period , if you recharge at say 75% charge , the battery memory starts and then it doesn't matter how long you charge the battery for , it will only charge 25% which means you wind up with a flat battery more often
so how to overcome the problem---the more you use it the quicker the battery runs down and when recharging always allow the battery to be less than 5% charge before recharging it ( dead flat is best) and leave it on charge for the max amount of time ( overnight is best)
Apr 22, 2016 | Cell Phones
Battery charger issue
funny thing with batteries is that they can get a memory = sounds stupid yes = if a battery is recharged when it has half charge and then fully charged it remembers the point , one it gains memory it wont charge past the last point = or the battery life is over = or the charger is faulty.
Jun 12, 2014 | Samsung S1030 Digital Camera
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Apr 22, 2013 | Nintendo Wii Remote Control 4 Charging...
How do i know it charging
The DVR 508HD is a video camera, not a battery charger. As such it doesn't charge batteries at all. It uses three standard AAA batteries, either disposables or rechargeables. If you use rechargeables, they must be recharged outside the camera using a separate charger.
Nov 16, 2012 | Vivitar DVR 508HD Digital Video Recorder
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
Battery charge is only good for 15to20 seconds---24volt-----bought aug 2010 ---l24wg165x1p-----serial#45667----please advise soon as possible------j.campbell ---phone419-836-5516------cell...
Your battery has probably just reached the end of it's service life, or developed a memory after repeated chargeings without being fully depleted. All rechargeable batteries have an average maximum number of duty cycles. (drain and charge) If your charger has a deep cycle feature, try using this to completely drain and recharge the battery. If it doesn't, try putting it in your trimmer and locking the trigger back for a few hours, then recharge it. If neither of these work, it's time for a new battery. If you do get a new battery, be sure to COMPLETELY drain the battery before recharging by locking the trigger back every few uses to avoid developing a memory and help extend the life of your new battery.
May 31, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I bought a psyclone essentials Wii charge station with 2 batteries PX6522. However, when I lay the batteries down on the inductive charging pad, nothing lights up (not the red for charging or green for...
I know this is an old post, and you likely don't need the answer anymore, but It appears that the programming in the induction pad can get screwed up and it won't actually detect that the batteries are there. By unplugging the station and leaving it unplugged for a bit, then plugging it back in you can normally reset the pad and get it to detect (and charge) the batteries again.
Jan 12, 2011 | Video Game Consoles & Games
My Psyclone recharge station ruined my Wii remotes.
Try taking the batteries out and leave them out for a couple of minutes replace them and try again.
If it still does not work the rechargable batteries may be shot. You can test this by replacing the rechargable ones with disposable ones and see if the remote works then.
If it does then buy some new rechargable batteries.
I hope this helps
Nov 14, 2008 | Nintendo Wii Console
RECHARGABLE BATYERY DOESN´T CHARGE
you probably will have to go and buy a whole new one. theses kind of batteries only last about 1 year.
Oct 21, 2008 | Durabrand PDV-709
Nintendo Wii Console Logo
67 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
