Question about Acer Aspire One PC Notebook
How to burn CD of installed drivers & s/w form Acer Aspireone ZG5
I have an Acer Aspireone ZG5 gifted to me. I want to make create tow partitions on the the HDD for my convenience. I have not yet done any thing to the HDD. It is still in the original state ( present state of the HDD is an un-accecable partition PQSERVICE of 4.88 Gb EISA configuration and volume C of 144.7 Gb). The help file states that on first startup you get an option so that you can make this backup CD. Unfortunately I was not the first person to start the computer since I have been gifted it. when I start the eRecovery I get an option to install the 15 odd drivers & s/w listed on connect tag but i can not burn these on a cd for use after formatting the HDD. Could some one help me solve my problem?
Let to do this thing let buy cd optional driver to accelerate the driver it seft to boot as possible access, to proper loading. coz it will requered buy the manufacturer,tats why they have an option system to boot.
Posted on Jul 23, 2009
    President:
  • 2,653 Answers
You can try THIS.
I think this version is free, but I'm not sure. I've never used a program like it before.
I usually don't bother backing up drivers since they are always being updated and are easy to acquire.
Posted on Jun 15, 2009
How to fix error 17 by starting windows xp at acer aspire zg5
Error 17 sounds like a grub bootloader problem, IE: your Acer disk didn't perhaps reload the boot code for Windows, or remove grub entirely.
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
which can repair what windows has ruined and is unable to fix fix the problem
either burn it to a disk as an iso and install
you might have burn it to an iso first then boot from the cd rom to install ubuntu or you might just try to install ubuntu directly from the download if it does not install you might save it to a folder then burn it as an isohttp://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
once Ubuntu has been installed on your computer has corrected the fault you will be able to reinstall windows
or keep ubuntu and install windows next door to it
you can have a dual boot computer with both windows and ubuntu linux you will need to partition your hard drive to do this
is a free partition program.
I have actually used this process to fix my computer with similiar problems and it works.
also
You might want to look at this
http://en.kioskea.net/forum/affich-4...aspire-one-zg5 also
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer pressENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Nov 27, 2013 | Computers & Internet
I have replaced my hard drive but the back up discs I made are not working, I keep getting the error 'no partition'
You need to create a partition on your new hard disk and the format this partition as a NTFS partition.
You can use your Windows installation CD to create and format the hard disk and then install Windows plus the Acer laptop device drivers or quit Windows installation after formatting and then use your backup discs to restore your laptop.
Jun 05, 2011 | Acer Extensa 4220-2148 Notebook
I want 2 formet my leptop acer aspire one bt i dnt knw how tow do it can u tel me abt it
This is generally how you format the hard disk and install Windows.
First you need a Windows XP Home or Professional installation CD and theproduct installation code.
Boot up with the Windows installation CD start and follow the instructions toinstall Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quickformat. This will prepare the Windows for a clean install.
Next create a User(name).
Further into the installation, you will be required to put in the Installationcode.
When you finished installing Windows you need to install the laptop's devicedrivers. You need to use a computer with Internet access to download thesedrivers from the laptop manufacturer's WEB site and install these drivers onyour laptop.
Next connect a LAN cable to the LAN port from your computer to your DSL orcable modem and you need to Activate the Windows installation on the MicrosoftWEB site.
Next up need to upgrade Windows from the Microsoft WEB site including SP2 &3.
Next you need to install your programs
May 13, 2011 | Acer Aspire One PC Notebook
I want to downlaod window xp on my acer zg5 . i can't pls help
providing that you have enough room on the harddrive all you should have to do is insert the cd and turn off the computer and restart than it will say boot from cd than it will say boot from cd press any key than after this it should start the examining process and after this it will ask you if you want to install or upgrade or repair say either upgrade or install and go from their.
If it shows the partition with the current version on it you can delete the partition or create a new partition so this is up to you but be advised if you delete the partition all data (will) be lost ok ? and you will have to create a partition DONT FORGET THIS STEP IF YOU DECIDE TO DELETE THE PARTITION OK? BUT IF if no partition is shown just continue with the installation and the rest is very self explanitory ok? i hope this helped out a lot
best regards michael
Sep 24, 2009 | Computers & Internet
Aspire one won't load xp
IDE0 is probaby the bootable recovery partition you're using to start up with. You should have an option to create a partition. Do this, make sure it's NTSF and then select the partition you made.
May 04, 2009 | Acer Aspire 3000 Notebook
Hi I have a Acer Aspire One ZG5. My Son, said his friend used a program called Killdisk and wiped all my partitions away. How can I get my Acer back up and working? Kind Regards Julie
try formatting your computer use a windows os but make sure it is bootable for example windows vista bootable cd. after that try installing the motherboard installer for you to use the full benefit of your computer then try installing an antivirus for security purposes then try making a password for your computer so your son cannot use the computer without your concern. so it wont happen again. hope i helped message me again for any concerns ok
May 03, 2009 | Computers & Internet
New Laptop
The laptop has an eRcovery partition the will restore it to original condition.
Acer eRecovery
At the Acer splash screen, you can press Alt and F10 (at the same time you would press F2 to enter the BIOS) to bring up a DOS style version of eRecovery.
· The unit is able to reload Windows from this mode faster then from CD.
· The password by default is 000000 (6 zeros) and it is displayed when you are asked for the password.
· Users are able to change the password in this mode for eRecovery only.
· The system can recover from the hidden image on the hard drive (PQService partition) or from CD/DVD media.
· It is possible to reload from the factory style CDs/DVD or the snapshots that the Windows version of eRecovery creates.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 14, 2008 | Acer TravelMate 2300 Notebook
Bluetooth & Nokia PC Suite
hi, i seems u have installed the B T correctly, now to connect to the internet u need to creat a DUN (Dial Up Networking) there you can provide the ISP dial up No. Username etc...if u can see a Bluetooth icon on the right bottom corner, right click on it, u will have a option for DUN there,once there u will figure it out..let me know..
Jan 09, 2008 | Computers & Internet
How to install windows xp on new Acer Aspire L320 computer
you can set the partitions in f-disk on the start up disk of windows 98, reset partitions to 32, format c: drive, take out disk and put in windows 98 cd. and restart computer. your done. windows 98 cd will install. your up and running. please give me a fixya rateing. Thanks farren
Dec 20, 2007 | Microsoft Windows XP Professional for PC
Acer Aspire One  PC Notebook Logo
400 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
