Question about American Dryer 140009 - ADC Gas Valve
140010 looking for replacement
Telefunken TLC037fhda no sound picture good
take a look at the speaker,use a multimeter see if the speaker have the rated resistance.( eg .8 ohms) if speaker bad replace if.if speaker good. see if your audio amp is getting power (multimeter needed) set to d.c volts.have voltage then look for the input pin that brings audio into the amp,use a 16 -32 ohms speaker across gnd pin and input pin(bring volume up hi on tv) if audio replace audio amp.
(also look for cold solder) on p.c board before replacing amp.
May 23, 2014 | Televison & Video
Display window dim
I would open it up and look at the connections to see if any can be replaced. Look for any darkened or burned looking connectors related to the display panel. Hopefully you won't need to replace the display panel circuit board but if you do. I would look for the cheapest replacement starting with ebay parts, and search engines for that specific part. Sometimes there are microwaves of different models with the same parts too!
Nov 07, 2013 | Maytag MMV4205 Microwave Oven
Looking for barbie dream house replacement parts.
barbie dream house replacement parts can be found on amazon, click here and take a look: Amazon com barbie dream house parts. I hope this was helpful. Cheers
Oct 13, 2012 | Toys
Need a replacement lid for my aroma indoor grill
Hi, not sure if you are still looking for a replacement lid for your Aroma Health Grill but we have just listed an Aroma Health Grill on eBay, Model AHG-1125. It is used but in great condition. Take a look at
The listing ends on Sunday 22nd July at 8:51pm. Cheers.
May 14, 2012 | Aroma Health Grill AHG1125
Iriver story screen is bumped and broken, how to get a replacement screen
I did some searching around and found out that you contact LG's support department for a replacement screen.
As for prices, you're looking at around 40 euros more than what a new Kindle costs.
I looked on eBay for a replacement screen and couldn't find anything. Just keep looking on eBay for a new screen, or just fork over the money and contact the mfg. for a replacement.
Mar 07, 2011 | iRiver Story
I am looking for replacement earpads for Sony MDR V600 headphones. Will replacement pads for MDR 7506 fit the V600?
Yes, the replacement pad for mdr 7506 fits in for the v600. They can be replaced for one another. There are different types of v600 and 7506, You just have to look for the 7506 that looks more like the v600. That should do the job for you. Hope this information helped You.
Jan 13, 2011 | Sony MDR-V6 Professional Headphones
We bought a compaq presario 700 off of ebay and it had a 14.4 volt battery in it. can we replace it with a 14.8? Does this cause any problems?
.4 volts should not be a problem. Ideally when you're replacing a battery, you want an exact match. If the replacement batteries you've looked at are all 14.8 volts, the tolerance should be within the laptop's ability to handle. I would not recommend going more than a volt over, but never under. .4 volts should not harm the laptop at all.
If you feel uneasy about this small difference, go with looking for a 14.4 volt battery. If you can't locate one, or if all the replacements are 14.8 volts, then the 14.8 volt battery should be good. Take a look at the battery itself and look for a manufacturing label. On that label may be a part number or a "replace with part number." Look for that part number on ebay, Compaq's website or some other electronics outlet.
Dec 05, 2010 | Compaq Presario 700 470024-192 Notebook
My 2000 honda accord have over 150,00 miles on it do i need to have the time change replaced
if you mean timing chain/belt, then i would have to say.... maybe.
it should be replaced every 60,000 miles. if it was done 20,000 miles ago then it should NOT need replacing. if it is the same one that came on it in 2000 with 150,000 on it (which i doubt) then replace it immediately. peel back the cover and look at it. if it looks cracked, frayed, etc then replace it. if it looks good then leave it.
Oct 06, 2010 | 2000 Honda Accord
Trampoline bungee broke and I need to buy a replacement.
Hi ajrother...
Amazon provides many products, so take a look there. This one can help you Upper Bounce Replacement Elastic Bungee Cords for Trampoline Jumping Mats... (If fits of course).
Also you can contact the seller if helps. Hope this was helpful. enjoy
Oct 02, 2009 | Galt Folding Trampoline
Looking to replace flasher switch looking for location
Left hand side of dash behind instrument cluster with your speedo, instrument cluster needs to come out to replace it.
Jun 16, 2009 | 1998 Buick Century
American Dryer 140009 - ADC Gas Valve Logo
Top American Dryer Dryers Experts
Dan Webster
Dan Webster
Are you an American Dryer Dryer Expert? Answer questions, earn points and help others
