Question about Seymour Duncan Dave Mustaine Live Wire Pickup Set New
Pickups I burned up a potentiometer/pot while installing my livewire pickups is there any other potentiometers I can use instead of the pots that came with it which are 15a 100k 1201 q or 100k(pt-010) If there is I would be greatly appreciated to know what they are thanks Harlan.
  • Michael Hubert
    Michael Hubert Sep 25, 2016
    did you ever find a pot and if so can you link the page? Nothing seems to be the exact thread size i'm looking for when i look at 100k pots
    Top Expert:
  • Seymour Duncan Master
  • 3,113 Answers
The simplest way to make sure you get the right pot is get it from Duncan. Here is the link- Contact Form
Posted on Sep 26, 2016
Try this first with the piano off, run the control from stop to stop rapidly several times. The object is to clean off any dust deposits and shine the contacts inside the pot. If the pot is not damaged beyond repair, then this should fix it.
Dec 05, 2016 | Casio Cdp-100 88 Note Digital Piano
Where can I find a wiring diagram?
if your replacing the existing pots. the values should be on the
backs of them. usually 500k for volume if using humbuckers and 100k for the tone pots. if your using single coil pick ups. its usually 100k across the board. but if you still need a diagram. what is the make and model of the instrument?
Aug 16, 2014 | Music
My ME 70 is auto skipping. Example, from one effect to another without me touching any button. an electrician said it just need cleaning, but even after he cleaned it, it still has the same problem. please...
"Auto skipping. Example, from one effect to another".
Is it always so, or only sometimes?
What type of effect? Is it happen at the all Type of parameter? It can be observed from the changes sound is heard.
Yes "it just need cleaning", but, which parts are cleaned,and how he did? Is it potentiometer?
And if he simply cleaned by spraying contact cleaner, this is not effective at all, because it does not touch at all the inside of the pot.
Potentiometer need to be replaced, but if it is difficult to find, open the back lid of potensio. Fix the inside (you have to understand the potentiometer structure inside).
ME70 pots are look like this :
Sep 12, 2013 | Boss ME-70 Guitar Multiple Effects Pedal
How to replace a potentiometer
Disconnect from the mains.
Unscrew the four screws in the top
Slide out the chassis
Remove the knobs
Unscrew the pot nuts
Unclip/unscrew the PCB
Unsolder the pot
Solder in new one.
Re-assemble in reverse order
Strongly suggest you youse a better quality pot
Also the treble pot tends to go on these, replace at same time
All the best, Chris
Apr 14, 2013 | Marshall MG15DFX 15 Watt Compact 2...
I nned mxr fullbore pots replacements
Usually with volume pots,the ratings dont matter. you can really buy then anywhere like guitar center,micro center and online. they're really cheap and well worth it.
Oct 04, 2017 | MXR M-116 Fullbore Metal Guitar Effects...
There is an audible hiss/distorted noise when the volume nob is turned. is this a sign of a failing potentiometer?
its accumulation of dust particles in the POT. Clean it by pouring alcohol into the POT and keep turning it around(with power off) and it will clear
Jul 08, 2011 | Polk Audio Psw10 10" Monitor Series...
I have a dean vendetta xm and it wont make sound through an amp they wiring is correct (checked through diagram provided by dean)
If the wiring is correct on the guitar, try plugging it in to a different amp. If you still don't get any sound, the problem may be a faulty volume or tone potentiometer (or pot. The knob, for simpler words). These are fairly easy to replace if you know how to solder. If not, then watch this video:
You can get the pots from Musician's Friend, Guitar Center, or any music store that carries guitar parts.
If that doesn't fix it, then the problem is in your pickups. You can get "aftermarket" pickups through the above mentioned dealers, and you're not restricted to the original pickups.
What you replace them with will affect your tone, so do some research before settling on a set of pickups. Active pickups will give you more gain (great for nu-metal and hi-gain applications) and have lower output noise, but they require batteries. Passive pickups have no need for batteries, but tend to produce slightly more noise and hum.
Hopefully, it's the pots. That will be the cheaper fix, since they run about $2-$4USD each. Pickups can range from $100-$500USD a set.
Hope that helps!
Jan 20, 2011 | Dean Vendetta XM Electric Guitar
What potentiometer is being used in rbx 374 bass volume control..because i replaced it with a500 potentiometer but still its not working..i bought yhe bass second hand,,is potentiometers for active pickups...
Yes, active use different value pots than passive. The volume control is LIKELY an "audio taper" which can be either an "A" or a "B" marking as there is confusion about the marking. The resistance is likely around 500K ohms down to as low as 50K ohms. The marking MIGHT be something like 504 B or 503 B or the same with the letter "A".
An A500 pot might be only 50 ohms... That would result in very low output. Again, the marking in the industry is not consistent.
Best bet is to get the part from Yamaha. Go to Yamaha America "parts" dept in California. You can search the phone number with Google.
Oct 10, 2010 | Yamaha Rbx374 4String Electric Bass Guitar
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
There is a repetative clicking sound whenever I use the treble on my guitar. what is causing this?
Did you mean the treble control potentiometer (knob)?
This was posted as an amplifier problem, but since you mentioned that the use of the treble (button?) on the guitar is causing the clicking, i would have the treble potentiometer checked first.
It could have a loosely soldered or broken wire on any of the tabs, oxydized slider contacts, bad ground (negative) connnection, possibly dirt or damage on the resistive track inside the pot.
A broken wire can easily be resoldered, but if there is internal damage or oxydation, the potentiometer should be either cleaned or replaced.
In short words - it may be a faulty treble pot.
There are ways to disassemble and clean a potentiometer, but the difficulty of this task may vary and depends mostly on the type and build of the pot.
The other alternative is to have it replaced.
Sep 26, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Seymour Duncan Dave Mustaine Live Wire Pickup Set New Logo
Top Seymour Duncan Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Seymour Duncan Music Expert? Answer questions, earn points and help others
