Question about Vacucraft Vacuum Seal Lids VC-004
How to use a vacucraft container
How many pumps
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Leaking washer bottle
Could be your pump is leaking or where pump goes into container,a rubber fitting is in the inlet and pump part goes thru rubber part to seal,it could be worn and leaking,you will have to remove container and pump to exam.
Nov 27, 2012 | Cars & Trucks
How do you refill roundup pump and go
The Pump N Go can be refilled with either the Roundup Super Concentrate or Roundup Ready To Use Plus Refill Bottle.
To refill the Pump N Go with the Roundup Super Concentrate (purple cap), add 6.5 fl oz of the Super Concentrate to container and slowly fill with water.
To refill with the Ready To Use Plus Refill bottle, just slowly fill the Pump N Go with the refill container.
We do not recommend using Roundup Concentrate Plus (red cap) to refill the Pump N Go because it has different active ingredients and different information regarding use around edibles.
To open to Pump N Go container, please follow the directions below:
Stabilize container by holding between your feet
While holding the pump handle push down slightly and turn left (the pump will be out of the locked position)
The first time it is opened it will be difficult to open because for shipping safety the top is but on very tightly at the factory.
If you have any further questions, please contact us at 877-465-5160.
Hilary @Roundup
Aug 29, 2011 | Roundup "" Weed & Grass Killer
I cant get my foundation pump dispenser to pump out the fluid
You may try using a cleanse off oil to clean your liquid foundation pump. Pour some cleanse off oil into a clean container and soak your pump therein for 15 to 20 minutes. Then, try to use a stick (preferably the stick of a q-tip) to take off excess foundation left in the pump's tube. Lastly, using the foundation pump, try to pump the cleanse off oil from the container.
Apr 20, 2011 | M+ Mac Cosmetics Liquid Foundation Pump...
What is the procedure for draining the gas out of the tank to change the fuel pump
ok..
  • remove the negative battery terminal
  • open the gas lid and remove the tank cover.
  • under the car , under the gas tank is a drain valve , Its like a bolt)
  • connect a running hose and let water flow under the car, (optional)
  • get a large flat container
  • remove the drain valve from the tank and let the gas run out into the container. when its almost full cover back the valve, empty the container in a gas container an then continue to drain.
easier method but most people say its unsafe,
you need a hose and a gas container,
  1. pop the hood,
  2. locate the gas filter
  3. remove the hose leading to the gas filter, put it in your hose and place the other end in the gas container (ITS LIKE YOUR extending the hose to your gas container instead of the filter.
  4. turn on the ignition and watch the gas pump out the tank to your container, (pump must be working for this to work)
Apr 02, 2011 | Buick Regal Cars & Trucks
How do I replace a washer pump on a 2004 silverado 2500HD
Remove the air cleaner, then remove the washer container. Then unhook the washer tubes. Next remove the pump by carefully pulling the pump from the retainer on the container. Then remove the pump from the sealing grommet. Put the sealing grommet on the new pump then push it back into the retainer on the container. Hook back up your hoses then proceed to put the washer container back in and the same with the air cleaner.
Feb 04, 2010 | 2004 Chevrolet Silverado 2500HD
1998 Mercury Sable window washer pump repair?
on passager side in the windshield washer container easy fix 11mm socket remove container change pump that it thanks for using fixya pierre
Mar 07, 2008 | Baby Gear
Vacucraft Vacuum Seal Lids VC-004 Logo
56 people viewed this question
Top Vacucraft Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vacucraft Kitchen Appliances - Other Expert? Answer questions, earn points and help others
