Question about Whirlpool 24 in. ADP6940 Dishwasher
The 3h green light is flashing - Whirlpool 24 in. ADP6940 Dishwasher
2 Suggested Answers
  • 6277 Answers
SOURCE: awg5122 not draining light over
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 05, 2011
Need manual for jmb hb250 breadmaker and recipes
Using the JMB HB-250 Bread Maker
Those of you who have acquired the HB-250 bread-maker without a manual may require some advice on how to get started. I do not have a user or service manual but have used this machine for some time.
How to load the tin.
For this bread-maker to work flawlessly it is best to load the ingredients in the following order: A basic bread recipe is included as an example:
First Liquids. 300ml water
Second Flour. If you aerate it so much the better. 500grams
Third Ingredients in each corner:
salt / butter / milk powder (if desired) / sugar.
1 tps salt / 15 grms butter / 2 tps mik powder / 1.1/2 tps sugar
Fourth Yeast. Make an indentation in the centre of the flour and tip in the
contents of the sachet. Sachet is 7 grms.
You are ready to go. You can get loads of recipes by trawling the web.
Operation.
This is a very simple machine and it gets the job done without complications. It is what it is without all the bells and whistles. You must observe the cooking times because it is no good starting a whole-wheat loaf at 3:0pm hoping it will be ready for 5:0pm
There are six selections to choose from: Basic, W.Wheat, Sweet, French, Cake, and Dough. The approximate time cycles for each of the selections is as follows:
  • Basic 190min 3h 10m
  • W.Wheat 230min 3h 50m
  • Sweet 200min 3h 20m
  • French 210min 3h 30m
  • Cake 85min 1h 25m
  • Dough 75min 1h 15m
  1. Plug the unit into the wall socket and switch on. A long beep is heard and the green indicator above the ON/OFF switch is illuminated.
  2. Using the Select button press and choose the method for your bread. A green indicator will show you which selection you have made.
  3. Press the On/Off button to start the bread-maker. The chosen selection indicator will start flashing
Note: Once started the machine will continue to the end of the cycle.
Stopping the Bread-maker. To switch OFF or reset the operation press and hold the ON/OFF button until the machine resets and the selection indicator stop flashing. The machine is now in its OFF position. If required you can re-select a program or just switch off.
W. Wheat Selection - Using this selection the machine appears to do nothing when switched on. It will take 30 minutes before you hear the machine in operation. Do not assume it is not working it is. The heater slowly increases the working temperature required by the ingredients.
Once cooking starts - don't be tempted to lift the lid to see what is happening. Buy a high-powered LED torch and view the workings through the window on the top of the machine. Opening the lid destroys the internal temperature; this will cause your bread to deflate.
Adding extras: If you want to add fruits or olives etc to your loaf; wait until 8 beeps is heard then add. This will be approximately half way through the proving cycle
End of cycle: The Morse code for VICTORY (as 3 sets of dit dit dit dah.) is heard.
May 17, 2011 | Kitchen Appliances - Others
Hello, I have a question: how many hours do i have to recharge my Philips GoGear SA018 mp3 player? In the guide its written to keep it for 3h and when the light is green it means its recharged,however...
If its new and your having this problem DO NOT hesitate to take it back. However most new gadgets when charging for the first time may require a bit more charging time than stated in the manuals.
If the problem persists take it back.
Aug 12, 2010 | Philips GoGear Clip SA018102S/02 2 GB MP3...
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Display flashes 3h
Hello sir; H3 code require a reset procedure as follow;
press "clear", "expoaure", "clear", "exposure", then enter 14 press start, it will back to normal.
Oct 02, 2009 | Sharp AL-1642CS Copier
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Xerox xc 1045
H3 is a fuser problem, check lamp or thermofuse
Oct 31, 2008 | Office Equipment & Supplies
Sharp AL-1631 has 3H error code
3H error means overheating...what you can do is supply new fans or clean the unit for dust and others. check for the exhaust fans if its still working. this will reslove your problem.
hope this helps
Jan 27, 2008 | Sharp AL 1631 Copier
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Whirlpool 24 in. ADP6940 Dishwasher Logo
21 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
